New Adjustable VetteNet Windscreen
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
The long awaited release of VetteNets Version 3 has now arrived.
Version 3 is now vertically adjustable, eliminating the top bar from
blocking your rear-view mirror.
Features
•Virtually eliminates wind buffeting and turbulence into the cockpit.
•Extends your "top down" driving season
•Helps control interior temperature and air flow
•Allows you to hear your stereo or carry on a conversation at highway speed
•Lightweight black aluminum frame installs in minutes
•Stores easily in the trunk.
•NEW Adjustable Height.
Please visit the following link to purchase your New VetteNet
http://www.customcorvetteaccessories...dblockers.html
Peace
Chip
The Vette Net is shipped with two brackets, one for the right side and one for left. The Vette Net is configured to go up and over your center waterfall.
Open the hatch cover, set each bracket over the hinge on each side of the car located behind the seat belt. Legs should be pointed downward toward the carpet so that the hatch will close. A strong push on the hatch will lock the brackets and the hatch in place.
Insert the Vette Net legs into each pipe and gently tap on the top of the net to make sure it sets all the way down into the legs
Close the hard boot.
Peace
Chip
Peace
Chip
![](/forums/images/ranks/100-500.gif)
Are you saying that the brackets can be installed and removed without the use of tools? Do the brackets work ok with power tops? Is there enough room between the Vette Net and hatch to keep them from touching, while driving?
Peace
Chip
yes they are the same! got mine from chip a couple weeks ago. i also have a 2011 gs and it works as advertised. oh, and by the way chip gives some of the best customer service in the buisness. chip if you read this thanks for everything.
carl
carl
![](/forums/images/ranks/1k-2k.gif)
How close in color is the Anniversary Red to Torch Red. Do you have any pix of the red frames?
