How do I bleed the clutch??
![](/forums/images/ranks/2k-3k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Go with the Ranger method. Is very, very easy.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
http://forums.corvetteforum.com/c6-t...al-issues.html
Thank you. I did try this method before, but I was wondering if there was another thread somewhere about how bleed the clutch. Entire procedure in detail. Kinda like the brakes that would help me...
![](/forums/images/ranks/100-500.gif)
Take my word for not bleeding the clutch like you bleed the brakes. The main reason is that the bleed value is very very very hard to reach and operate and like brake fluid and transmission fluid, when the value is opened the fluid goes over everything within the immediate area. What a mess and the smell if it get on parts that get hot. You never can get the area totally clean.
The Ranger method is the easiest, cleanest and quickest way to change the clutch fluid.
Mike
Mike
Last edited by Mike's Sweet 19; 05-21-2010 at 05:36 PM. Reason: grammer correction
The old-fashioned way: Uscrew the bleed valve (located on the slave cylinder, very hard to reach - http://forums.corvetteforum.com/c6-z...he-clutch.html), then press the clutch pedal down. Screw the valve back in, then let the clutch up. Unscrew, then press the clutch down. Screw in, then let the clutch up.
Do that while keeping fresh fluid in the master cylinder reservoir until the fluid comes out of the bleed valve clean. This requires 2 people. Don't let up the clutch while the bleed valve is loose, you'll get air in the system.
Old fashioned way +1: Get a remote bleeder. It's basically a hose you attach to the bleed valve location. This makes it a 1-man job as the hose is usually long enough for you to reach while you're pressing the clutch.
Modern way: Get a pressure bleeder like motive or mity-vac/etc. These either create pressure (motive) or a vaccum(mity-vac), so you'd attach the device to either the clutch reservoir (motive) or bleed valve (mity-vac) and push/suck the fluid through the system while the bleed valve is open and keeping the reservoir full.
The problem with these is they won't get old fluid out of either the master/slave cylinder (I forgot) as it is not a straight-through system. I'd recommend the motive power bleeder as its easier to use and you can also use it to bleed your brakes.
The absolutely easy fool-proof method: The Ranger method. Disadvantage: You'll spend an extra $6 on fluid as you need extra to clean out the system. My man, $6 is well worth the time it will save doing the other methods
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
![](/forums/images/ranks/7k-10k.gif)
The absolutely easy fool-proof method: The Ranger method. Disadvantage: You'll spend an extra $6 on fluid as you need extra to clean out the system. My man, $6 is well worth the time it will save doing the other methods![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
exactly....
![Smash](https://www.corvetteforum.com/forums/images/smilies/smash.gif)
