Non-Ethanol Gas Anyone using it???
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I pulled into a newly renovated Sunoco station and the pump island I pulled into had the normal nozzle and a blue colored nozzle that was for 90 octane non-ethanol gas. I normally use 91 octane with ethanol additives. The non-ethanol was about 40 cents higher than reg unleaded.![Frown](https://www.corvetteforum.com/forums/images/smilies/frown5.gif)
Has any one switched to this gas and how did your corvette respond to the different type gas?![Lurk](https://www.corvetteforum.com/forums/images/smilies/lurk5.gif)
Thanks for your help
Mike
Mike
I'd gladly pay 40 cents a more per gallon for non-ethanol gas if I could find it. Problem is, there are very few stations left that even sell it, for any price. It's pretty much impossible to get in Texas. Other states may have it more readily available, but not many of the southern states do.
Funny thing is, most all the states where corn is grown offer non-ethanol gas. Its about the only gas the farmers will buy. They all know better than put ethanol laced gas in their own equipment. Instead, the ship it all south to states where it is mandated, and laugh all the way to the bank.
Ethanol is the biggest scam ever pulled on the American public in history.
![](/forums/images/ranks/1k-2k.gif)
Location: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
Mike
Mike
In the state of Florida that pump should have been marked "For Non Highway Use Only"
Fred H. - WELL SAID!
I am unaware of "blue nozzle" non-ethanol gas pumps here in SE PA. May I assume this is available so people with outboard motors (where it would be more critical) and small power equipment engines don't run the risk of ruining their fuel systems like I did with my snowblower a couple of years ago?
![](/forums/images/ranks/3k-4k.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
I only fill up at one station in my town. I fill up with 92 octane premium with NO ethanol in my vette. I don't run ethanol at all in my DD unless it will be way below zero. Ethanol helps the fuel from freezing. That is the ONLY good thing I can say about ethanol.
![](/forums/images/ranks/7k-10k.gif)
![](/forums/images/ranks/11k.gif)
In Missouri, gas stations can sell their premium with or without ethanol, at their discretion. The problem is, they don't have to mark their pumps so the only way you know if you are buying 100% pure gas or the E10 crap is to ask them before you start filling up. We have several stations that sell 91 octane without ethanol and I use their premium for my Mercedes and my 56 and 64 Vettes. We have two stations that sell 94 octane without ethanol and that is what I use in my Z06. I cry like a baby when I go out of town in my Z06 and have to put the E10 crap in it.
I run Ethanol every now and then in my Avalanche....flex fuel, it runs better 105 octane but you lose 3 mpg and it needs to be about 40 cents less to compare price-wise with regular fuel...I have ran it off and on for about two years. It was $2.29 gal for a year or so but with prices now it has spiked to around $3.38 or so...obviously it is not recommended for our cars.
Received 2,062 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
BTW, a quick search for the freezing point of gasoline produced results in the -100 degree range, so don't fret about that issue.
it wasn't very popular i remember my dad getting it somtimes at a Phillips 66 station
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
I get non-oxy gas all the time. Its very common around the rivers and lakes here in MN sence boats need it. Ethanol gas loves to absorb water and if it sits too long the gas turns to crap and the boat will run like crap. We also use non-oxy in all our off road toys, snowmobiles, atvs, and should be used in small engines. The 91 non-oxy gas by my house does say off road use only but I some how forget to read that every time
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
![](/forums/images/ranks/5k-6k.gif)
![Crazy2](https://www.corvetteforum.com/forums/images/smilies/crazy2.gif)
I would also gladly pay 40 cents more for real gas but I can't find it anywhere any more. It used to be a requirement that stations had a sticker on the pump if it was "gasahol" but since most gas is now E10 because of the tax subsidies, it seems to no longer be required.
Can't even find non ethanol gas in NY state. Hell, we don't even have a Shell station here. E15 is right around the corner just wait and see then the real engine problems will start, starting with ALL small engines like your weed wacker's and lawn mowers.
I work for a company which makes ethanol (among other things) but I won't even put it in my family SUV. As someone already mentioned, ethanol contains less energy/gallon than gasoline, so I'm willing to pay extra to get better fuel economy and reduce the chances of premature corrosion on parts which don't like alcohol.
I'm lucky that the BP in my small town doesn't add ethanol. The Shell station in the larger city south of me only offers their V Power with ethanol, such a crock!
There is one station on my commute with no ethanol but they are usually a bit more expensive than the other stations nearby. I've run a few tankfulls of non-ethanol 93 thru the Z and did not notice a significant change in performance or fuel economy.
Granted, this was just measuring over my normal commute (some city, highway and spirited driving) so it was not much of a controlled study.
![](/forums/images/ranks/4k-5k.gif)
I go out of my way to put only 100% gas in all my cars.....
I have posted link this before... Its a list of stations that sell pure gas...
http://pure-gas.org/index.jsp?stateprov=TN
Goon Squad King of Battle
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
![](https://www.corvetteforum.com/forums/images/ranks/stjude15.jpg)
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
