Continental DWS Tires? Anyone have any experience with this brand and type of tire?
![](/forums/images/ranks/11k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
ExtremeContact DWS(Ultra High Performance All-Season)
Sidewall Style: Blackwall
Click thumbnails to view above.
Most approximate photos shown
View Full Screen Photo. 2005 Chevrolet Corvette C6 Coupe Standard Model
Front: 245/40ZR18
Serv. Desc: 93Y Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “Y” = 186mph (300kph)
UTQG: Treadwear: 540
Traction: A
Temperature: A540 A A Price: $164.00 (each)
Estimated Availability: In Stock
Qty:
0 1 2 3 4 5 6 7 8 Includes Manufacturer's Road Hazard Warranty
Rear: 285/35ZR19
Serv. Desc: 99Y Load Index 99 = 1709lbs (775kg) per tire
Traction: A
Temperature: A540 A A Price: $277.00 (each)
Qty:
Set of 4: $882.00
The ExtremeContact DWS (DWS for Dry, Wet & Snow) is Continental's Ultra High Performance All-Season radial developed for drivers of sports cars, sports coupes, performance sedans and sport trucks. The ExtremeContact DWS is designed to satisfy their year-round driving needs by blending dry and wet road performance with light snow and slush traction.
ExtremeContact DWS features an advanced silica-based, high-grip, all-season tread compound molded into a unique asymmetrical tread design with stable shoulder blocks and a continuous, notched intermediate rib on the outboard side to enhance responsiveness and cornering stability. The center of the tread features independent blocks separated by high-angle, crisscross grooves to provide the biting edges necessary to deliver wet road and light snow traction while independent inboard shoulder blocks help disperse water to further enhance hydroplaning resistance and foul weather traction.
The ExtremeContact DWS features Tuned Performance Indicators — visible letters molded into the second rib from the outboard shoulder to alert drivers of the tire's performance levels. A visible "DWS" indicates the tire has sufficient tread depth for dry conditions, as well as wet roads and light snow. After the "S" has worn away, the remaining "DW" indicates the tire only has sufficient tread depth for dry and most wet road conditions. And after the "W" and "S" have both worn away, the remaining "D" indicates the tire has appropriate tread depth for dry conditions only.
The tire's internal structure includes twin steel belts reinforced with spirally wound jointless nylon cap plies to provide long-term integrity under high-speed conditions while reducing weight and helping to provide more uniform ride quality.
Front: 245/40ZR18
Traction: A
Qty:
Rear: 285/35ZR19
Traction: A
Qty:
Set of 4: $882.00
![](/forums/images/ranks/3k-4k.gif)
I have them on my CTS as a replacement to the Michelin PS2's. In my experience it is a very good tire and an excellent choice if you want to transition from a summer ultra performance tire to an all-season performance tire. Quiet, good ride and good wear rate at minimal cost to performance and feedback.
![](/forums/images/ranks/1k-2k.gif)
Front: 245/40ZR18
Traction: A
Qty:
Rear: 285/35ZR19
Traction: A
Qty:
Set of 4: $882.00
Add To Cart Shipping Quote Add to Wish List
Important Notes Product Description Other Sizes & Pricing Specs Surveys Reviews Tests Warranty Important Notes:
Lea en español
Read this page in English
El neumático ExtremeContact DWS (Dry, Wet y Snow: seco, mojado y nieve) de Continental pertenece a la categoría: Ultra Alto Rendimiento Para Toda Estación y fue desarrollado para conductores de autos deportivos, cupé deportivo, sedán de rendimiento y camiones ligeros deportivos. El ExtremeContact DWS ha sido diseñado para satisfacer la necesidad que tienen los conductores, durante todas las estaciones del año, al combinar el rendimiento sobre superficies secas y mojadas, con tracción sobre poca nieve y aguanieve.
El ExtremeContact DWS (Dry, Wet y Snow: seco, mojado y nieve) posee una mezcla de caucho basada en sílice de gran agarre para su uso durante todas las temporadas del año. Esta mezcla es moldeada en una banda de rodamiento asimétrica con bloques o tacos estables en los hombros y un segmento intermedio cóncavo continuo en la parte de afuera (opuesta al motor), que mejora la respuesta y la estabilidad al tomar curvas. El centro de la banda de rodamiento posee bloques independientes separados por ángulos abiertos, además, ranuras que se cruzan proveen la “mordida” necesaria para proporcionar tracción sobre superficies mojadas y con poca nieve. Bloques independientes en el hombro interno (cerca del motor), ayudan a dispersar el agua y así mejoran la resistencia al deslizamiento en agua (hydroplaning) y la tracción en condiciones climatológicas difíciles.
El ExtremeContact DWS, posee indicadores Tuned Performmance , estos, son letras moldeadas en el segundo segmento de la parte exterior del hombro, para alertar al conductor los niveles de rendimiento del neumático. Una marca visible con las letras DWS indica que el neumático tienen suficiente profundidad para su uso sobre superficies secas, mojadas y con poca nieve. Luego de que la letra “S” se desgasta las letras “DW” indican que el neumático solamente posee un profundidad para trabajar óptimamente sobre superficies secas y la mayoría de superficies mojadas. Y cuando se desgasta, la letra “W” la letra restante “D”, indica que la profundidad de la banda solo es apropiada sobre superficies secas.
La estructura interna del neumático incluye correas gemelas de acero reforzadas con capas sin unión de nailon envuelto en espiral, para proporcionar una integridad a largo plazo bajo velocidades elevadas, al mismo tiempo de reducir peso y proporcionar un andar más uniforme.
What sizes will fit my 2005 Chevrolet Corvette C6 Coupe Standard Model? Select New Vehicle
Applicable sizes are marked with (front) and (rear). View Applicable Matching Front & Rear Pairs
PriceSizeServ. Desc.195/50ZR16 84W Load Index 84 = 1102lbs (500kg) per tire
Speed Rating “W” = 168mph (270kph) $103.00 (ea.)
205/45ZR16 83W Load Index 83 = 1074lbs (487kg) per tire
Speed Rating “W” = 168mph (270kph) $106.00 (ea.)
205/50ZR16 87W Load Index 87 = 1201lbs (545kg) per tire
Speed Rating “W” = 168mph (270kph) $111.00 (ea.)
205/55ZR16 91W Load Index 91 = 1356lbs (615kg) per tire
215/55ZR16 93W Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “W” = 168mph (270kph) $110.00 (ea.)
225/50ZR16 92W Load Index 92 = 1389lbs (630kg) per tire
225/55ZR16 95W Load Index 95 = 1521lbs (690kg) per tire
205/45ZR17 88W Load Index 88 = 1235lbs (560kg) per tire
Speed Rating “W” = 168mph (270kph) $117.00 (ea.)
205/50ZR17 93W Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “W” = 168mph (270kph) $131.00 (ea.)
215/45ZR17 91W Load Index 91 = 1356lbs (615kg) per tire
Speed Rating “W” = 168mph (270kph) $116.00 (ea.)
215/50ZR17 95W Load Index 95 = 1521lbs (690kg) per tire
Speed Rating “W” = 168mph (270kph) $132.00 (ea.)
215/55ZR17 94W Load Index 94 = 1477lbs (670kg) per tire
Speed Rating “W” = 168mph (270kph) $130.00 (ea.)
225/45ZR17 91W Load Index 91 = 1356lbs (615kg) per tire
Speed Rating “W” = 168mph (270kph) $126.00 (ea.)
225/50ZR17 94W Load Index 94 = 1477lbs (670kg) per tire
Speed Rating “W” = 168mph (270kph) $138.00 (ea.)
235/45ZR17 94W Load Index 94 = 1477lbs (670kg) per tire
Speed Rating “W” = 168mph (270kph) $128.00 (ea.)
235/50ZR17 96W Load Index 96 = 1565lbs (710kg) per tire
Speed Rating “W” = 168mph (270kph) $164.00 (ea.)
235/55ZR17 99W Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “W” = 168mph (270kph) $153.00 (ea.)
245/40ZR17 91W Load Index 91 = 1356lbs (615kg) per tire
Speed Rating “W” = 168mph (270kph) $139.00 (ea.)
245/45ZR17 95W Load Index 95 = 1521lbs (690kg) per tire
Speed Rating “W” = 168mph (270kph) $137.00 (ea.)
245/50ZR17 99W Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “W” = 168mph (270kph) $165.00 (ea.)
255/40ZR17 94W Load Index 94 = 1477lbs (670kg) per tire
255/45ZR17 98W Load Index 98 = 1653lbs (750kg) per tire
Speed Rating “W” = 168mph (270kph) $163.00 (ea.)
275/40ZR17 98W Load Index 98 = 1653lbs (750kg) per tire
Speed Rating “W” = 168mph (270kph) $179.00 (ea.)
215/35ZR18 84Y Load Index 84 = 1102lbs (500kg) per tire
Speed Rating “Y” = 186mph (300kph) $136.00 (ea.)
215/40ZR18 89Y Load Index 89 = 1279lbs (580kg) per tire
Speed Rating “Y” = 186mph (300kph) $146.00 (ea.)
215/45ZR18 93Y Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “Y” = 186mph (300kph) $151.00 (ea.)
225/40ZR18 92Y Load Index 92 = 1389lbs (630kg) per tire
Speed Rating “Y” = 186mph (300kph) $142.00 (ea.)
225/45ZR18 91Y Load Index 91 = 1356lbs (615kg) per tire
Speed Rating “Y” = 186mph (300kph) $150.00 (ea.)
235/35ZR18 86Y Load Index 86 = 1168lbs (530kg) per tire
Speed Rating “Y” = 186mph (300kph) $131.00 (ea.)
PriceSizeServ. Desc.235/40ZR18 91Y Load Index 91 = 1356lbs (615kg) per tire
Speed Rating “Y” = 186mph (300kph) $154.00 (ea.)
235/45ZR18 98Y Load Index 98 = 1653lbs (750kg) per tire
Speed Rating “Y” = 186mph (300kph) $180.00 (ea.)
235/50ZR18 97W Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “W” = 168mph (270kph) $178.00 (ea.)
235/55ZR18 100W Load Index 100 = 1764lbs (800kg) per tire
Speed Rating “W” = 168mph (270kph) $183.00 (ea.)
245/45ZR18 96Y Load Index 96 = 1565lbs (710kg) per tire
Speed Rating “Y” = 186mph (300kph) $176.00 (ea.)
255/35ZR18 90Y Load Index 90 = 1323lbs (600kg) per tire
Speed Rating “Y” = 186mph (300kph) $219.00 (ea.)
255/40ZR18 99Y Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “Y” = 186mph (300kph) $201.00 (ea.)
255/45ZR18 103Y Load Index 103 = 1929lbs (875kg) per tire
Speed Rating “Y” = 186mph (300kph) $188.00 (ea.)
255/55ZR18 109W Load Index 109 = 2271lbs (1030kg) per tire
Speed Rating “W” = 168mph (270kph) $199.00 (ea.)
265/35ZR18 97Y Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “Y” = 186mph (300kph) $247.00 (ea.)
265/40ZR18 101Y Load Index 101 = 1819lbs (825kg) per tire
Speed Rating “Y” = 186mph (300kph) $232.00 (ea.)
275/35ZR18 95Y Load Index 95 = 1521lbs (690kg) per tire
Speed Rating “Y” = 186mph (300kph) $259.00 (ea.)
275/40ZR18 99Y Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “Y” = 186mph (300kph) $237.00 (ea.)
285/30ZR18 93Y Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “Y” = 186mph (300kph) $235.00 (ea.)
285/35ZR18 101Y Load Index 101 = 1819lbs (825kg) per tire
Speed Rating “Y” = 186mph (300kph) $265.00 (ea.)
295/35ZR18 99Y Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “Y” = 186mph (300kph) $227.00 (ea.)
215/35ZR19 85Y Load Index 85 = 1135lbs (515kg) per tire
225/35ZR19 88Y Load Index 88 = 1235lbs (560kg) per tire
Speed Rating “Y” = 186mph (300kph) $167.00 (ea.)
225/40ZR19 93Y Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “Y” = 186mph (300kph) $169.00 (ea.)
235/35ZR19 91Y Load Index 91 = 1356lbs (615kg) per tire
Speed Rating “Y” = 186mph (300kph) $177.00 (ea.)
245/35ZR19 93Y Load Index 93 = 1433lbs (650kg) per tire
Speed Rating “Y” = 186mph (300kph) $196.00 (ea.)
245/40ZR19 94Y Load Index 94 = 1477lbs (670kg) per tire
Speed Rating “Y” = 186mph (300kph) $222.00 (ea.)
245/45ZR19 98Y Load Index 98 = 1653lbs (750kg) per tire
255/35ZR19 96Y Load Index 96 = 1565lbs (710kg) per tire
Speed Rating “Y” = 186mph (300kph) $228.00 (ea.)
255/50ZR19 107W Load Index 107 = 2149lbs (975kg) per tire
Speed Rating “W” = 168mph (270kph) $221.00 (ea.)
265/30ZR19 93Y Load Index 93 = 1433lbs (650kg) per tire
275/30ZR19 96Y Load Index 96 = 1565lbs (710kg) per tire
Speed Rating “Y” = 186mph (300kph) $243.00 (ea.)
275/35ZR19 100Y Load Index 100 = 1764lbs (800kg) per tire
Speed Rating “Y” = 186mph (300kph) $260.00 (ea.)
PriceSizeServ. Desc.275/40ZR19 101Y Load Index 101 = 1819lbs (825kg) per tire
Speed Rating “Y” = 186mph (300kph) $258.00 (ea.)
275/45ZR19 108W Load Index 108 = 2205lbs (1000kg) per tire
Speed Rating “W” = 168mph (270kph) $255.00 (ea.)
285/30ZR19 98Y Load Index 98 = 1653lbs (750kg) per tire
Speed Rating “Y” = 186mph (300kph) $277.00 (ea.)
295/30ZR19 100Y Load Index 100 = 1764lbs (800kg) per tire
Speed Rating “Y” = 186mph (300kph) $245.00 (ea.)
225/30ZR20 85Y Load Index 85 = 1135lbs (515kg) per tire
Speed Rating “Y” = 186mph (300kph) $152.00 (ea.)
225/35ZR20 90Y Load Index 90 = 1323lbs (600kg) per tire
235/30ZR20 88Y Load Index 88 = 1235lbs (560kg) per tire
Speed Rating “Y” = 186mph (300kph) $168.00 (ea.)
245/30ZR20 90Y Load Index 90 = 1323lbs (600kg) per tire
Speed Rating “Y” = 186mph (300kph) $208.00 (ea.)
245/35ZR20 95Y Load Index 95 = 1521lbs (690kg) per tire
Speed Rating “Y” = 186mph (300kph) $184.00 (ea.)
245/40ZR20 99Y Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “Y” = 186mph (300kph) $241.00 (ea.)
245/45ZR20 99W Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “W” = 168mph (270kph) $253.00 (ea.)
255/35ZR20 97Y Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “Y” = 186mph (300kph) $158.00 (ea.)
255/45ZR20 105W Load Index 105 = 2039lbs (925kg) per tire
Speed Rating “W” = 168mph (270kph) $223.00 (ea.)
265/30ZR20 94Y Load Index 94 = 1477lbs (670kg) per tire
Speed Rating “Y” = 186mph (300kph) $213.00 (ea.)
265/35ZR20 99Y Load Index 99 = 1709lbs (775kg) per tire
275/30ZR20 97Y Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “Y” = 186mph (300kph) $254.00 (ea.)
275/35ZR20 102Y Load Index 102 = 1874lbs (850kg) per tire
Speed Rating “Y” = 186mph (300kph) $268.00 (ea.)
275/40ZR20 106W Load Index 106 = 2094lbs (950kg) per tire
285/30ZR20 99Y Load Index 99 = 1709lbs (775kg) per tire
Speed Rating “Y” = 186mph (300kph) $262.00 (ea.)
295/40ZR20 110W Load Index 110 = 2337lbs (1060kg) per tire
Speed Rating “W” = 168mph (270kph) $257.00 (ea.)
315/35ZR20 110W Load Index 110 = 2337lbs (1060kg) per tire
Speed Rating “W” = 168mph (270kph) $233.00 (ea.)
235/30ZR22 90Y Load Index 90 = 1323lbs (600kg) per tire
Speed Rating “Y” = 186mph (300kph) $242.00 (ea.)
245/30ZR22 92Y Load Index 92 = 1389lbs (630kg) per tire
255/35ZR22 99Y Load Index 99 = 1709lbs (775kg) per tire
265/30ZR22 97Y Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “Y” = 186mph (300kph) $275.00 (ea.)
285/30ZR22 101Y Load Index 101 = 1819lbs (825kg) per tire
295/25ZR22 97Y Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “Y” = 186mph (300kph) $295.00 (ea.)
255/30ZR24 97W Load Index 97 = 1609lbs (730kg) per tire
Speed Rating “W” = 168mph (270kph) $269.00 (ea.)
Currently Selected Tire Size(s)
Size
Service Description
Load Range UTQG Max
Load Max.
Inflation
Press. Tread
Depth Tire
Weight Rim
Width
Range Meas.
Rim
Width Sect.
Width Tread
Width Overall
Diam. Revs
Per
Mile Country
of Origin*
245/40ZR18
Speed Rating “Y” = 186mph (300kph) 93Y SL Treadwear: 540
Traction: A
Temperature: A540 A A 1433 lbs.
51 psi
10/32"
23 lbs. 8-9.5"
8.5"
9.8"
NA
25.7"
811
Country of Origin "MX" = MEXICOMX , Country of Origin "PT" = PORTUGALPT
285/35ZR19
Speed Rating “Y” = 186mph (300kph) 99Y SL Treadwear: 540
Traction: A
Temperature: A540 A A 1709 lbs.
51 psi
10/32"
28 lbs. 9-11"
10"
11.4"
10.6"
26.9"
772
Country of Origin "CZ" = CZECH REPUBLICCZ , Country of Origin "BR" = BRAZILBR
All Other Sizes for this Tire
[+] Show
Size
Service Description
Load Range UTQG Max
Load Max.
Inflation
Press. Tread
Depth Tire
Weight Rim
Width
Range Meas.
Rim
Width Sect.
Width Tread
Width Overall
Diam. Revs
Per
Mile Country
of Origin*
195/50ZR16
Speed Rating “W” = 168mph (270kph) 84W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1102 lbs.
51 psi
10/32"
17 lbs. 5.5-7"
6"
8.5"
7.2"
23.7"
864
Country of Origin "FR" = FRANCEFR , Country of Origin "BR" = BRAZILBR
205/45ZR16
Speed Rating “W” = 168mph (270kph) 83W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1047 lbs.
51 psi
17 lbs. 0-0"
NA
Country of Origin "BR" = BRAZILBR , Country of Origin "DE" = GERMANYDE
205/50ZR16
Speed Rating “W” = 168mph (270kph) 87W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1201 lbs.
51 psi
10/32"
19 lbs. 5.5-7.5"
6.5"
8.4"
7.4"
24.1"
853
205/55ZR16
Speed Rating “W” = 168mph (270kph) 91W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1356 lbs.
51 psi
10/32"
21 lbs. 5.5-7.5"
6.5"
8.4"
NA
24.9"
831
215/55ZR16
Speed Rating “W” = 168mph (270kph) 93W SL Treadwear: 540
Traction: A
51 psi
10/32"
20 lbs. 6-7.5"
7"
8.9"
NA
25.3"
824
225/50ZR16
Speed Rating “W” = 168mph (270kph) 92W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1389 lbs.
51 psi
10/32"
21 lbs. 6-8"
7"
9.2"
NA
24.9"
831
225/55ZR16
Speed Rating “W” = 168mph (270kph) 95W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1521 lbs.
51 psi
10/32"
22 lbs. 6-8"
7"
9.2"
NA
25.7"
811
205/45ZR17
Speed Rating “W” = 168mph (270kph) 88W XL Treadwear: 540
Traction: A
Temperature: A540 A A 1235 lbs.
51 psi
10/32"
20 lbs. 6.5-7.5"
7"
8.4"
NA
24.3"
855
205/50ZR17
Speed Rating “W” = 168mph (270kph) 93W XL Treadwear: 540
Traction: A
51 psi
10/32"
20 lbs. 5.5-7.5"
6.5"
8.5"
7.2"
25.1"
825
215/45ZR17
Speed Rating “W” = 168mph (270kph) 91W XL Treadwear: 540
Traction: A
51 psi
11/32"
20 lbs. 7-8"
7"
8.5"
NA
24.6"
839
215/50ZR17
Speed Rating “W” = 168mph (270kph) 95W XL Treadwear: 540
Traction: A
51 psi
10/32"
21 lbs. 6-7.5"
7"
8.9"
NA
25.5"
818
Country of Origin "BR" = BRAZILBR , Country of Origin "MX" = MEXICOMX
215/55ZR17
Speed Rating “W” = 168mph (270kph) 94W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1477 lbs.
51 psi
10/32"
21 lbs. 6-8"
7"
9.2"
NA
26.3"
793
Country of Origin "US" = UNITED STATES OF AMERICAUS , Country of Origin "FR" = FRANCEFR , Country of Origin "DE" = GERMANYDE
225/45ZR17
Traction: A
51 psi
10/32"
21 lbs. 7-8"
7.5"
8.9"
NA
25"
828
Country of Origin "DE" = GERMANYDE , Country of Origin "PT" = PORTUGALPT , Country of Origin "BR" = BRAZILBR
225/50ZR17
Traction: A
51 psi
10/32"
22 lbs. 6-8"
7"
9.2"
NA
25.9"
805
235/45ZR17
Traction: A
51 psi
11/32"
22 lbs. 7.5-9"
8"
9.3"
NA
25.3"
824
235/50ZR17
Speed Rating “W” = 168mph (270kph) 96W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1565 lbs.
51 psi
10/32"
24 lbs. 6.5-8.5"
7.5"
9.7"
NA
26.3"
793
235/55ZR17
Speed Rating “W” = 168mph (270kph) 99W SL Treadwear: 540
Traction: A
51 psi
10/32"
24 lbs. 6.5-8.5"
7.5"
9.6"
8.3"
27.2"
767
Country of Origin "US" = UNITED STATES OF AMERICAUS , Country of Origin "BR" = BRAZILBR
245/40ZR17
Traction: A
51 psi
10/32"
23 lbs. 8-9.5"
8.5"
9.8"
NA
24.7"
836
245/45ZR17
Traction: A
51 psi
11/32"
24 lbs. 7-9"
8"
9.6"
NA
25.7"
811
245/50ZR17
Traction: A
51 psi
10/32"
25 lbs. 6.5-8.5"
7.5"
9.7"
NA
26.3"
793
255/40ZR17
Traction: A
51 psi
10/32"
23 lbs. 8.5-10"
9"
10.2"
NA
25"
828
255/45ZR17
Speed Rating “W” = 168mph (270kph) 98W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1653 lbs.
51 psi
10/32"
25 lbs. 8-9.5"
8.5"
10.2"
NA
26"
802
Country of Origin "DE" = GERMANYDE , Country of Origin "BR" = BRAZILBR
275/40ZR17
Traction: A
51 psi
10/32"
26 lbs. 9-11"
9.5"
10.9"
9.5"
25.7"
811
215/35ZR18
Speed Rating “Y” = 186mph (300kph) 84Y XL Treadwear: 540
Traction: A
51 psi
10/32"
18 lbs. 7-8"
7.5"
8.6"
NA
23.9"
859
215/40ZR18
Speed Rating “Y” = 186mph (300kph) 89Y XL Treadwear: 540
Traction: A
Temperature: A540 A A 1279 lbs.
51 psi
10/32"
20 lbs. 7-8.5"
8.5"
10"
NA
24.8"
834
Country of Origin "MX" = MEXICOMX , Country of Origin "BR" = BRAZILBR
215/45ZR18
Speed Rating “Y” = 186mph (300kph) 93Y XL Not currently
available for
this tire.Pending 1433 lbs.
51 psi
10/32"
21 lbs. 7-8"
7"
8.4"
NA
25.6"
814
Country of Origin "MX" = MEXICOMX , Country of Origin "DE" = GERMANYDE
225/40ZR18
Speed Rating “Y” = 186mph (300kph) 92Y XL Treadwear: 540
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9"
NA
25.1"
825
225/45ZR18
Speed Rating “Y” = 186mph (300kph) 91Y SL Treadwear: 540
Traction: A
51 psi
11/32"
22 lbs. 7-8.5"
7.5"
8.9"
NA
26"
802
235/35ZR18
Speed Rating “Y” = 186mph (300kph) 86Y SL Treadwear: 540
Traction: A
Temperature: A540 A A 1168 lbs.
51 psi
10/32"
21 lbs. 8-9.5"
8.5"
9.5"
NA
24.5"
848
Country of Origin "PT" = PORTUGALPT , Country of Origin "CZ" = CZECH REPUBLICCZ
235/40ZR18
Traction: A
51 psi
10/32"
22 lbs. 8-9.5"
8.5"
9.5"
NA
25.4"
821
235/45ZR18
Speed Rating “Y” = 186mph (300kph) 98Y XL Treadwear: 540
Traction: A
51 psi
10/32"
22 lbs. 7.5-9"
8"
9.3"
NA
26.3"
793
235/50ZR18
Speed Rating “W” = 168mph (270kph) 97W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1609 lbs.
51 psi
10/32"
24 lbs. 6.5-8.5"
8"
9.6"
NA
27.3"
764
Country of Origin "MX" = MEXICOMX , Country of Origin "FR" = FRANCEFR
235/55ZR18
Speed Rating “W” = 168mph (270kph) 100W SL Treadwear: 540
Traction: A
Temperature: A540 A A 1764 lbs.
51 psi
10/32"
28 lbs. 6.5-8.5"
7.5"
9.6"
NA
28.2"
739
Country of Origin "DE" = GERMANYDE , Country of Origin "CZ" = CZECH REPUBLICCZ
245/45ZR18
Speed Rating “Y” = 186mph (300kph) 96Y SL Treadwear: 540
Traction: A
51 psi
11/32"
24 lbs. 7.5-9"
8"
9.6"
NA
26.7"
781
Country of Origin "MX" = MEXICOMX , Country of Origin "US" = UNITED STATES OF AMERICAUS , Country of Origin "PT" = PORTUGALPT
255/35ZR18
Speed Rating “Y” = 186mph (300kph) 90Y SL Treadwear: 540
Traction: A
Temperature: A540 A A 1323 lbs.
51 psi
10/32"
23 lbs. 8.5-10"
9"
10"
NA
25"
828
255/40ZR18
Speed Rating “Y” = 186mph (300kph) 99Y XL Treadwear: 540
Traction: A
51 psi
10/32"
26 lbs. 8.5-10"
9"
10.2"
NA
26"
802
255/45ZR18
Speed Rating “Y” = 186mph (300kph) 103Y XL Treadwear: 540
Traction: A
Temperature: A540 A A 1929 lbs.
51 psi
11/32"
28 lbs. 8-9.5"
8.5"
10"
NA
27"
772
Country of Origin "US" = UNITED STATES OF AMERICAUS , Country of Origin "DE" = GERMANYDE
255/55ZR18
Speed Rating “W” = 168mph (270kph) 109W XL Treadwear: 540
Traction: A
Temperature: A540 A A 2271 lbs.
51 psi
10/32"
33 lbs. 7-9"
8"
10.4"
NA
29"
719
Country of Origin "US" = UNITED STATES OF AMERICAUS , Country of Origin "CZ" = CZECH REPUBLICCZ
265/35ZR18
Speed Rating “Y” = 186mph (300kph) 97Y XL Treadwear: 540
Traction: A
51 psi
10/32"
25 lbs. 9-10.5"
9.5"
10.7"
8.7"
25.3"
824
265/40ZR18
Speed Rating “Y” = 186mph (300kph) 101Y XL Treadwear: 540
Traction: A
Temperature: A540 A A 1819 lbs.
51 psi
10/32"
28 lbs. 9-10.5"
9.5"
11.2"
10"
26.3"
793
275/35ZR18
Speed Rating “Y” = 186mph (300kph) 95Y SL Treadwear: 540
Traction: A
51 psi
10/32"
26 lbs. 9-11"
9.5"
11.2"
9.5"
25.6"
814
275/40ZR18
Traction: A
51 psi
10/32"
26 lbs. 9-11"
9.5"
10.9"
10"
26.7"
781
285/30ZR18
Traction: A
51 psi
10/32"
24 lbs. 9.5-10.5"
10"
11.5"
11"
24.7"
841
285/35ZR18
Traction: A
51 psi
10/32"
28 lbs. 9.5-11"
10"
11.4"
10"
25.9"
805
295/35ZR18
Traction: A
51 psi
10/32"
27 lbs. 10-11"
10.5"
12"
11.5"
26.1"
799
215/35ZR19
Speed Rating “Y” = 186mph (300kph) 85Y XL Treadwear: 540
Traction: A
Temperature: A540 A A 1135 lbs.
51 psi
10/32"
20 lbs. 7-8"
7.5"
8.6"
NA
24.9"
831
225/35ZR19
Speed Rating “Y” = 186mph (300kph) 88Y XL Treadwear: 540
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9.1"
NA
25.2"
827
225/40ZR19
Speed Rating “Y” = 186mph (300kph) 93Y XL Treadwear: 540
Traction: A
51 psi
10/32"
22 lbs. 7.5-9"
8"
9.1"
NA
26.1"
799
235/35ZR19
Speed Rating “Y” = 186mph (300kph) 91Y XL Treadwear: 540
Traction: A
51 psi
10/32"
22 lbs. 8-9.5"
8.5"
9.5"
NA
25.5"
818
245/35ZR19
Traction: A
51 psi
10/32"
22 lbs. 8-9.5"
8.5"
9.8"
NA
25.8"
808
245/40ZR19
Speed Rating “Y” = 186mph (300kph) 94Y SL Treadwear: 540
Traction: A
51 psi
10/32"
24 lbs. 8-9.5"
8.5"
9.8"
NA
26.7"
781
245/45ZR19
Speed Rating “Y” = 186mph (300kph) 98Y SL Treadwear: 540
Traction: A
51 psi
10/32"
25 lbs. 7.5-9"
8"
9.6"
NA
27.1"
753
255/35ZR19
Speed Rating “Y” = 186mph (300kph) 96Y XL Treadwear: 540
Traction: A
51 psi
10/32"
26 lbs. 8.5-10"
9"
10.3"
NA
26"
802
255/50ZR19
Speed Rating “W” = 168mph (270kph) 107W XL Treadwear: 540
Traction: A
Temperature: A540 A A 2149 lbs.
51 psi
10/32"
30 lbs. 7-9"
8"
10.4"
9.3"
29"
719
265/30ZR19
Traction: A
51 psi
10/32"
23 lbs. 9-10"
9.5"
10.7"
10.2"
25.3"
821
275/30ZR19
Traction: A
51 psi
10/32"
25 lbs. 9-10"
9.5"
10.9"
10.6"
25.5"
818
275/35ZR19
Speed Rating “Y” = 186mph (300kph) 100Y XL Treadwear: 540
Traction: A
51 psi
10/32"
27 lbs. 9-11"
9.5"
10.5"
10.5"
26.6"
800
Country of Origin "CZ" = CZECH REPUBLICCZ , Country of Origin "PT" = PORTUGALPT
275/40ZR19
Speed Rating “Y” = 186mph (300kph) 101Y SL Treadwear: 540
Traction: A
51 psi
10/32"
29 lbs. 9-11"
9.5"
11.1"
9.3"
27.7"
753
275/45ZR19
Speed Rating “W” = 168mph (270kph) 108W XL Treadwear: 540
Traction: A
Temperature: A540 A A 2205 lbs.
51 psi
10/32"
35 lbs. 8.5-10.5"
9"
10.7"
10"
28.7"
726
285/30ZR19
Traction: A
51 psi
10/32"
26 lbs. 9.5-10.5"
10"
11.4"
10"
25.7"
811
295/30ZR19
Traction: A
51 psi
10/32"
27 lbs. 10-11"
10.5"
12.2"
10.5"
26"
799
225/30ZR20
Speed Rating “Y” = 186mph (300kph) 85Y SL Treadwear: 540
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9"
NA
25.3"
824
225/35ZR20
Speed Rating “Y” = 186mph (300kph) 90Y XL Treadwear: 540
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9.1"
NA
26.2"
796
235/30ZR20
Traction: A
51 psi
10/32"
22 lbs. 8-9"
8.5"
9.8"
NA
25.6"
814
245/30ZR20
Traction: A
51 psi
10/32"
24 lbs. 8-9"
8.5"
9.8"
NA
25.8"
808
245/35ZR20
Speed Rating “Y” = 186mph (300kph) 95Y XL Treadwear: 540
Traction: A
51 psi
10/32"
24 lbs. 8-9.5"
8.5"
9.6"
NA
26.8"
778
245/40ZR20
Traction: A
51 psi
10/32"
27 lbs. 8-9.5"
8.5"
9.8"
NA
27.7"
775
245/45ZR20
Traction: A
51 psi
10/32"
26 lbs. 7.5-9"
8"
9.6"
NA
28.7"
726
255/35ZR20
Traction: A
51 psi
10/32"
26 lbs. 8-10"
9"
10.2"
NA
27"
772
255/45ZR20
Speed Rating “W” = 168mph (270kph) 105W XL Treadwear: 540
Traction: A
Temperature: A540 A A 2039 lbs.
51 psi
10/32"
28 lbs. 8-9.5"
8.5"
10"
NA
29"
719
265/30ZR20
Speed Rating “Y” = 186mph (300kph) 94Y XL Treadwear: 540
Traction: A
51 psi
25 lbs. 0-0"
9.5"
265/35ZR20
Traction: A
51 psi
10/32"
27 lbs. 9-10.5"
9.5"
10.7"
NA
27.3"
761
275/30ZR20
Traction: A
51 psi
10/32"
26 lbs. 9-10"
9.5"
10.4"
9.7"
26.5"
787
275/35ZR20
Speed Rating “Y” = 186mph (300kph) 102Y XL Treadwear: 540
Traction: A
Temperature: A540 A A 1874 lbs.
51 psi
10/32"
28 lbs. 9-11"
9.5"
11"
9.1"
27.6"
755
275/40ZR20
Speed Rating “W” = 168mph (270kph) 106W XL Treadwear: 540
Traction: A
Temperature: A540 A A 2094 lbs.
51 psi
10/32"
32 lbs. 9-10.5"
9.5"
10.9"
9"
28.7"
726
285/30ZR20
Traction: A
51 psi
28 lbs. 0-0"
11"
295/40ZR20
Speed Rating “W” = 168mph (270kph) 110W XL Treadwear: 540
Traction: A
Temperature: A540 A A 2337 lbs.
51 psi
35 lbs. 0-0"
11.1"
315/35ZR20
Traction: A
51 psi
10/32"
39 lbs. 10.5-12.5"
11"
12.6"
NA
28.7"
724
235/30ZR22
Traction: A
51 psi
24 lbs. 0-0"
8.7"
245/30ZR22
Speed Rating “Y” = 186mph (300kph) 92Y XL Treadwear: 450
Traction: A
Temperature: A450 A A 1389 lbs.
51 psi
10/32"
25 lbs. 8-9"
8.5"
9.7"
NA
27.8"
747
255/35ZR22
Traction: A
51 psi
10/32"
29 lbs. 8.5-10"
9"
10.2"
NA
29"
716
265/30ZR22
Traction: A
51 psi
10/32"
28 lbs. 9-10"
9.5"
10.4"
9"
28.3"
737
285/30ZR22
Traction: A
51 psi
10/32"
29 lbs. 9.5-10.5"
10"
11.4"
9.7"
28.7"
726
295/25ZR22
Traction: A
51 psi
10/32"
29 lbs. 10-11"
10.5"
11.6"
10.5"
27.8"
750
255/30ZR24
Speed Rating “W” = 168mph (270kph) 97W XL Treadwear: 540
Traction: A
51 psi
10/32"
27 lbs. 8.5-9.5"
9"
10.2"
NA
30"
695
Size
Service Description
Load Range UTQG Max
Load Max.
Inflation
Press. Tread
Depth Tire
Weight Rim
Width
Range Meas.
Rim
Width Sect.
Width Tread
Width Overall
Diam. Revs
Per
Mile Country
of Origin*
[-] Hide
NOTES:
Specifications shown are as accurate as possible based on the information provided to us by the tire manufacturers. The dimensions reflect average values for tires measured on the specified measuring rim width. Individual tires may vary from data shown.
All tires are subject to continuous development. The tire manufacturers and Tire Rack reserve the right to change product specifications at any time without notice or obligation.
*Although regularly updated, the country of origin for any tire may vary from the country shown here. Unfortunately, we cannot accommodate requests for tires with a specific country of origin.
If you have a specific concern please email sales@tirerack.com.
Results based on 1520 submissions of our online tire survey.
Surveyed Averages 1 100% 8.1 9.0 9.1 8.2 8.8 8.2 8.6 7.8 7.5 8.9 8.6 8.7 7,415,147
Color Key
Superior (8.6-10)
Fair (2.6-4.5)
Excellent (6.6-8.5)
Unacceptable (0-2.5)
Good (4.6-6.5)
Would You Buy This Tire Again?
Most said: "Probably" (Average of 8.1 out of 10)
How Did This Tire Rank In Its Category?
1 out of 24 tires (Score of 8.5 vs best tire in category score of 8.5)
See a Full List of Survey Results for Ultra High Performance All-Season Tires
LOADING RESULTS . . .
This product has not yet been reviewed. You can be the first!
Write a Review
Most Recent ReviewsRead all reviews for this tire | Write a review for this tire
710400 tireDetail
Continental ExtremeContact DWS (Ultra High Performance All-Season) Reviewer's Overall Rating: 7.7
2007 Audi A4 2.0T Quattro Premium Package Without TPMS More Tire Reviews for This Vehicle
35,000Miles driven on tires:
Paris, TNLocation:
Combined Highway/CityDriving Condition:
SpiritedDriving Style:
5 of 5 people found the following review helpful:
Initial Review, 35,000 Miles on Tires
June 29, 2011
Overall, the tires performed very well as expected. My routine driving involves a lot of 2 lane country roads with sharp turns and unexpected stops (i.e. deer, possums, and raccoons). My body count with tires was extremely low but not zero (sorry PETA). Anyway, my only negative response was tire wear. With a treadwear rating of 540, I expected closer to 50,000. To be fair, it could be my driving.
Was this review helpful? Yes No
You found this review helpful.
You did not find this review helpful.
Updating...
This is your own survey.
While we do not allow users to rate their own surveys, you may:
Submit a Follow-up Survey
See All of Your Surveys and Reviews
Was this review helpful? Registered users can answer "yes" or "no." Log In | Create an Account
710237 tireDetail
Continental ExtremeContact DWS (Ultra High Performance All-Season) Reviewer's Overall Rating: 8.43
2005 Mercedes-Benz E320 4Matic Appearance Package Standard Model More Tire Reviews for This Vehicle
2,500Miles driven on tires:
Newton, NJLocation:
AverageDriving Style:
1 of 2 people found the following review helpful:
Initial Review, 2,500 Miles on Tires
June 27, 2011
Seems like a great tire thus far...had them rotated once...wear looks,...very responsive ...and excellent blend of the extreme contact and touring...very quiet and comfortable ride...sharp 45mph curves and you feel the sidewells soften up a little...no noticeable difference in various suspension settings...thus far...probably the best tire i have purchased...will have to see how they deal with Jersey snow...they should be well broken in by then
Updating...
710231 tireDetail
Continental ExtremeContact DWS (Ultra High Performance All-Season) Reviewer's Overall Rating: 6.91
2004 Volkswagen Touareg V8 More Tire Reviews for This Vehicle
10,000Miles driven on tires:
stevensville, mdLocation:
1 of 3 people found the following review helpful:
Initial Review, 10,000 Miles on Tires
June 27, 2011
I put these tires on my 04 touareg v8(at the reccomendation of tire rack )I had a four wheel alignment done when they were installed and another after about 5,000 miles. The tires are almost worn out and i dont expect them to make it another 2,000 miles. I would never buy these tires again.
Updating...
Tire Rack's Latest Test SummaryTesting Bridgestone's Potenza RE970AS Pole Position Ultra High Performance A/S Tire (02:52)
After a successful run as a top-selling Ultra High Performance All-Season tire, Bridgestone replaced the Potenza RE960AS Pole Position with the new Potenza RE970AS Pole Position. While only a few numbers in the name have changed, there is plenty of advanced technology packed into this tire.
Watch as we test it against three top tires in the category.
Read the full test report.
View Additional Test Results
File size: 9.01 MB
Current download quality: medium
Change download quality: low | medium | high
Tires tested:
Bridgestone Potenza RE970AS Pole Position (Ultra High Performance All-Season)
Michelin Pilot Sport A/S Plus (Ultra High Performance All-Season)
Pirelli PZero Nero All Season (Ultra High Performance All-Season)
Latest Test Result Ratings
What We Liked: Good wet traction and quiet ride (On a Scale of 1 to 10)
What We'd Improve: Steering Response 7.51Ride Comfort
Conclusion: Still a very capable Ultra High Performance All Season tire that leads the category in wintertime survey results 7.32Noise Comfort
Latest Test Rank: 4th 7.49Dry Track
Previous Test Rank: 2nd (June '09) 7.63Wet Track
7.46Overall
Read Complete Test Results | View Additional Test Results
Treadlife Warranty: 6 Years / 50,000 miles
Uniformity Warranty: 1 Year / first 2/32" of wear
Workmanship & Materials Warranty: 6 Years / Free replacement first year or 2/32" of wear, then prorated until 2/32" remaining depth
Manufacturer's Road Hazard Warranty: 1 Year / first 2/32" of wear
Manufacturer Warranty Brochure: Download PDF
Manufacturer Special Warranty: 60-Day Customer Satisfaction Trial(1)
Additional Information: (1)exchange for another Continental brand tire
Overall Tire Warranty Rating*:
*Tire Rack's Tire Warranty Rating is an overall rating given to tire warranties after subjectively evaluating their value for the consumer. Warranties are rated on a scale of 0-5 with 5 being the highest. This rating combines all of the aspects of each tire's warranty where applicable, including: mileage/treadlife, materials and workmanship, balance and uniformity, replacement tire cost, warranty duration and any special manufacturer's warranties that apply. See official manufacturer's warranty brochure for specific details. The Original Equipment applications for this tire are not available online at this time. Please call 888-541-1777 to speak with one of our sales specialists. We apologize for any inconvenience this may cause.
Front: 245/40ZR18
Traction: A
Qty:
Rear: 285/35ZR19
Traction: A
Qty:
Set of 4: $882.00
Lea en español
Size
Service Description
Load Range UTQG Max
Load Max.
Inflation
Press. Tread
Depth Tire
Weight Rim
Width
Range Meas.
Rim
Width Sect.
Width Tread
Width Overall
Diam. Revs
Per
Mile Country
of Origin*
245/40ZR18
Traction: A
51 psi
10/32"
23 lbs. 8-9.5"
8.5"
9.8"
NA
25.7"
811
285/35ZR19
Traction: A
51 psi
10/32"
28 lbs. 9-11"
10"
11.4"
10.6"
26.9"
772
[+] Show
Size
Service Description
Load Range UTQG Max
Load Max.
Inflation
Press. Tread
Depth Tire
Weight Rim
Width
Range Meas.
Rim
Width Sect.
Width Tread
Width Overall
Diam. Revs
Per
Mile Country
of Origin*
195/50ZR16
Traction: A
51 psi
10/32"
17 lbs. 5.5-7"
6"
8.5"
7.2"
23.7"
864
205/45ZR16
Traction: A
51 psi
17 lbs. 0-0"
NA
205/50ZR16
Traction: A
51 psi
10/32"
19 lbs. 5.5-7.5"
6.5"
8.4"
7.4"
24.1"
853
205/55ZR16
Traction: A
51 psi
10/32"
21 lbs. 5.5-7.5"
6.5"
8.4"
NA
24.9"
831
215/55ZR16
Traction: A
51 psi
10/32"
20 lbs. 6-7.5"
7"
8.9"
NA
25.3"
824
225/50ZR16
Traction: A
51 psi
10/32"
21 lbs. 6-8"
7"
9.2"
NA
24.9"
831
225/55ZR16
Traction: A
51 psi
10/32"
22 lbs. 6-8"
7"
9.2"
NA
25.7"
811
205/45ZR17
Traction: A
51 psi
10/32"
20 lbs. 6.5-7.5"
7"
8.4"
NA
24.3"
855
205/50ZR17
Traction: A
51 psi
10/32"
20 lbs. 5.5-7.5"
6.5"
8.5"
7.2"
25.1"
825
215/45ZR17
Traction: A
51 psi
11/32"
20 lbs. 7-8"
7"
8.5"
NA
24.6"
839
215/50ZR17
Traction: A
51 psi
10/32"
21 lbs. 6-7.5"
7"
8.9"
NA
25.5"
818
215/55ZR17
Traction: A
51 psi
10/32"
21 lbs. 6-8"
7"
9.2"
NA
26.3"
793
225/45ZR17
Traction: A
51 psi
10/32"
21 lbs. 7-8"
7.5"
8.9"
NA
25"
828
225/50ZR17
Traction: A
51 psi
10/32"
22 lbs. 6-8"
7"
9.2"
NA
25.9"
805
235/45ZR17
Traction: A
51 psi
11/32"
22 lbs. 7.5-9"
8"
9.3"
NA
25.3"
824
235/50ZR17
Traction: A
51 psi
10/32"
24 lbs. 6.5-8.5"
7.5"
9.7"
NA
26.3"
793
235/55ZR17
Traction: A
51 psi
10/32"
24 lbs. 6.5-8.5"
7.5"
9.6"
8.3"
27.2"
767
245/40ZR17
Traction: A
51 psi
10/32"
23 lbs. 8-9.5"
8.5"
9.8"
NA
24.7"
836
245/45ZR17
Traction: A
51 psi
11/32"
24 lbs. 7-9"
8"
9.6"
NA
25.7"
811
245/50ZR17
Traction: A
51 psi
10/32"
25 lbs. 6.5-8.5"
7.5"
9.7"
NA
26.3"
793
255/40ZR17
Traction: A
51 psi
10/32"
23 lbs. 8.5-10"
9"
10.2"
NA
25"
828
255/45ZR17
Traction: A
51 psi
10/32"
25 lbs. 8-9.5"
8.5"
10.2"
NA
26"
802
275/40ZR17
Traction: A
51 psi
10/32"
26 lbs. 9-11"
9.5"
10.9"
9.5"
25.7"
811
215/35ZR18
Traction: A
51 psi
10/32"
18 lbs. 7-8"
7.5"
8.6"
NA
23.9"
859
215/40ZR18
Traction: A
51 psi
10/32"
20 lbs. 7-8.5"
8.5"
10"
NA
24.8"
834
215/45ZR18
available for
51 psi
10/32"
21 lbs. 7-8"
7"
8.4"
NA
25.6"
814
225/40ZR18
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9"
NA
25.1"
825
225/45ZR18
Traction: A
51 psi
11/32"
22 lbs. 7-8.5"
7.5"
8.9"
NA
26"
802
235/35ZR18
Traction: A
51 psi
10/32"
21 lbs. 8-9.5"
8.5"
9.5"
NA
24.5"
848
235/40ZR18
Traction: A
51 psi
10/32"
22 lbs. 8-9.5"
8.5"
9.5"
NA
25.4"
821
235/45ZR18
Traction: A
51 psi
10/32"
22 lbs. 7.5-9"
8"
9.3"
NA
26.3"
793
235/50ZR18
Traction: A
51 psi
10/32"
24 lbs. 6.5-8.5"
8"
9.6"
NA
27.3"
764
235/55ZR18
Traction: A
51 psi
10/32"
28 lbs. 6.5-8.5"
7.5"
9.6"
NA
28.2"
739
245/45ZR18
Traction: A
51 psi
11/32"
24 lbs. 7.5-9"
8"
9.6"
NA
26.7"
781
255/35ZR18
Traction: A
51 psi
10/32"
23 lbs. 8.5-10"
9"
10"
NA
25"
828
255/40ZR18
Traction: A
51 psi
10/32"
26 lbs. 8.5-10"
9"
10.2"
NA
26"
802
255/45ZR18
Traction: A
51 psi
11/32"
28 lbs. 8-9.5"
8.5"
10"
NA
27"
772
255/55ZR18
Traction: A
51 psi
10/32"
33 lbs. 7-9"
8"
10.4"
NA
29"
719
265/35ZR18
Traction: A
51 psi
10/32"
25 lbs. 9-10.5"
9.5"
10.7"
8.7"
25.3"
824
265/40ZR18
Traction: A
51 psi
10/32"
28 lbs. 9-10.5"
9.5"
11.2"
10"
26.3"
793
275/35ZR18
Traction: A
51 psi
10/32"
26 lbs. 9-11"
9.5"
11.2"
9.5"
25.6"
814
275/40ZR18
Traction: A
51 psi
10/32"
26 lbs. 9-11"
9.5"
10.9"
10"
26.7"
781
285/30ZR18
Traction: A
51 psi
10/32"
24 lbs. 9.5-10.5"
10"
11.5"
11"
24.7"
841
285/35ZR18
Traction: A
51 psi
10/32"
28 lbs. 9.5-11"
10"
11.4"
10"
25.9"
805
295/35ZR18
Traction: A
51 psi
10/32"
27 lbs. 10-11"
10.5"
12"
11.5"
26.1"
799
215/35ZR19
Traction: A
51 psi
10/32"
20 lbs. 7-8"
7.5"
8.6"
NA
24.9"
831
225/35ZR19
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9.1"
NA
25.2"
827
225/40ZR19
Traction: A
51 psi
10/32"
22 lbs. 7.5-9"
8"
9.1"
NA
26.1"
799
235/35ZR19
Traction: A
51 psi
10/32"
22 lbs. 8-9.5"
8.5"
9.5"
NA
25.5"
818
245/35ZR19
Traction: A
51 psi
10/32"
22 lbs. 8-9.5"
8.5"
9.8"
NA
25.8"
808
245/40ZR19
Traction: A
51 psi
10/32"
24 lbs. 8-9.5"
8.5"
9.8"
NA
26.7"
781
245/45ZR19
Traction: A
51 psi
10/32"
25 lbs. 7.5-9"
8"
9.6"
NA
27.1"
753
255/35ZR19
Traction: A
51 psi
10/32"
26 lbs. 8.5-10"
9"
10.3"
NA
26"
802
255/50ZR19
Traction: A
51 psi
10/32"
30 lbs. 7-9"
8"
10.4"
9.3"
29"
719
265/30ZR19
Traction: A
51 psi
10/32"
23 lbs. 9-10"
9.5"
10.7"
10.2"
25.3"
821
275/30ZR19
Traction: A
51 psi
10/32"
25 lbs. 9-10"
9.5"
10.9"
10.6"
25.5"
818
275/35ZR19
Traction: A
51 psi
10/32"
27 lbs. 9-11"
9.5"
10.5"
10.5"
26.6"
800
275/40ZR19
Traction: A
51 psi
10/32"
29 lbs. 9-11"
9.5"
11.1"
9.3"
27.7"
753
275/45ZR19
Traction: A
51 psi
10/32"
35 lbs. 8.5-10.5"
9"
10.7"
10"
28.7"
726
285/30ZR19
Traction: A
51 psi
10/32"
26 lbs. 9.5-10.5"
10"
11.4"
10"
25.7"
811
295/30ZR19
Traction: A
51 psi
10/32"
27 lbs. 10-11"
10.5"
12.2"
10.5"
26"
799
225/30ZR20
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9"
NA
25.3"
824
225/35ZR20
Traction: A
51 psi
10/32"
21 lbs. 7.5-9"
8"
9.1"
NA
26.2"
796
235/30ZR20
Traction: A
51 psi
10/32"
22 lbs. 8-9"
8.5"
9.8"
NA
25.6"
814
245/30ZR20
Traction: A
51 psi
10/32"
24 lbs. 8-9"
8.5"
9.8"
NA
25.8"
808
245/35ZR20
Traction: A
51 psi
10/32"
24 lbs. 8-9.5"
8.5"
9.6"
NA
26.8"
778
245/40ZR20
Traction: A
51 psi
10/32"
27 lbs. 8-9.5"
8.5"
9.8"
NA
27.7"
775
245/45ZR20
Traction: A
51 psi
10/32"
26 lbs. 7.5-9"
8"
9.6"
NA
28.7"
726
255/35ZR20
Traction: A
51 psi
10/32"
26 lbs. 8-10"
9"
10.2"
NA
27"
772
255/45ZR20
Traction: A
51 psi
10/32"
28 lbs. 8-9.5"
8.5"
10"
NA
29"
719
265/30ZR20
Traction: A
51 psi
25 lbs. 0-0"
9.5"
265/35ZR20
Traction: A
51 psi
10/32"
27 lbs. 9-10.5"
9.5"
10.7"
NA
27.3"
761
275/30ZR20
Traction: A
51 psi
10/32"
26 lbs. 9-10"
9.5"
10.4"
9.7"
26.5"
787
275/35ZR20
Traction: A
51 psi
10/32"
28 lbs. 9-11"
9.5"
11"
9.1"
27.6"
755
275/40ZR20
Traction: A
51 psi
10/32"
32 lbs. 9-10.5"
9.5"
10.9"
9"
28.7"
726
285/30ZR20
Traction: A
51 psi
28 lbs. 0-0"
11"
295/40ZR20
Traction: A
51 psi
35 lbs. 0-0"
11.1"
315/35ZR20
Traction: A
51 psi
10/32"
39 lbs. 10.5-12.5"
11"
12.6"
NA
28.7"
724
235/30ZR22
Traction: A
51 psi
24 lbs. 0-0"
8.7"
245/30ZR22
Traction: A
51 psi
10/32"
25 lbs. 8-9"
8.5"
9.7"
NA
27.8"
747
255/35ZR22
Traction: A
51 psi
10/32"
29 lbs. 8.5-10"
9"
10.2"
NA
29"
716
265/30ZR22
Traction: A
51 psi
10/32"
28 lbs. 9-10"
9.5"
10.4"
9"
28.3"
737
285/30ZR22
Traction: A
51 psi
10/32"
29 lbs. 9.5-10.5"
10"
11.4"
9.7"
28.7"
726
295/25ZR22
Traction: A
51 psi
10/32"
29 lbs. 10-11"
10.5"
11.6"
10.5"
27.8"
750
255/30ZR24
Traction: A
51 psi
10/32"
27 lbs. 8.5-9.5"
9"
10.2"
NA
30"
695
Size
Service Description
Load Range UTQG Max
Load Max.
Inflation
Press. Tread
Depth Tire
Weight Rim
Width
Range Meas.
Rim
Width Sect.
Width Tread
Width Overall
Diam. Revs
Per
Mile Country
of Origin*
[-] Hide
NOTES:
Color Key
Superior (8.6-10)
Fair (2.6-4.5)
Excellent (6.6-8.5)
Good (4.6-6.5)
Write a Review
710400 tireDetail
Paris, TNLocation:
June 29, 2011
Updating...
710237 tireDetail
Newton, NJLocation:
June 27, 2011
Updating...
710231 tireDetail
June 27, 2011
Updating...
File size: 9.01 MB
Tires tested:
7.46Overall
They are rated highly on Tire Rack, I have no experience with them other than they were hard to come by for my '09 XF.
I'm considering the Continental ExtremeContact DW (the "S" is added for "snow" use) summer tire.
The DW and DWS get great reviews everywhere I've read.
They're also near, or at the top, of every comparison test I've seen.
Somba master
![](https://www.corvetteforum.com/forums/images/ranks/veteran_air_force.png)
I got a set for my wife's Acura TL. Pretty good, but mushy turn in. They stick well, though. Quiet and smooth ride.
The rears are still in great shape but the fronts did wear a bit faster than rear tires.
Have you seen the cost of the OEM Goodyear Runflats?
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
![Crazy2](https://www.corvetteforum.com/forums/images/smilies/crazy2.gif)
![](/forums/images/ranks/100-500.gif)
I have them on my car. They are a huge improvement over the stock Goodyears. I do not regret getting rid of the stockers. Much cheaper than the Goodyears and with 6K miles on them now, they still look new. I can definately see them lasting near 40-50K (with reasonable driving of course).
![](/forums/images/ranks/7k-10k.gif)
Received 2,280 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Lurk](https://www.corvetteforum.com/forums/images/smilies/lurk5.gif)
I put DWS on my car last Fall - I was able to get around in the snow and they ride great for regular driving (I don't track the car). I have about 7- 8k mi on them and they are wearing well.
I'm thinking the Michelin all season runflat is a better tire. Not quite as good in the snow but better in dry weather conditions. Suppose to be quiet and soft ride and it's a runflat.
"Reviewer's Average Rating" is based on reviews
submitted by customers via our Online Tire Survey.
"N/A" denotes a tire that has not yet received
enough reviews to generate an average rating.N/AReviewer's
Avg. Rating: Special Offer:
Buy a set of four and get $70 value back.
Front: 245/40ZR18
RunFlat
Serv. Desc: (93Y)Load Index 93 = 1433lbs (650kg) per tire
Speed Rating "(Y)" = 186+mph (300kph)
UTQG: Treadwear: 500
Traction: AA
Temperature: A
500 AA APrice: $271.00 (each)
Qty:
012345678Optional Road Hazard Program: Add $17.55 per tire
Rear: 285/35ZR19
RunFlat
Serv. Desc: (99Y)Load Index 99 = 1709lbs (775kg) per tire
Traction: AA
Temperature: A
500 AA APrice: $345.00 (each)
Qty:
012345678Optional Road Hazard Program: Add $21.25 per tire
Add Road Hazard: $77.60
Set of 4: $1232.00
Add To Cart
Shipping QuoteAdd To Wish List
Alot more costly (Set of 4: $1232.00)
but not as bad as the F-1 Goodyears.
Continentials are:
enough reviews to generate an average rating.8.5Reviewer's
Avg. Rating: Front: 245/40ZR18
Serv. Desc: 93YLoad Index 93 = 1433lbs (650kg) per tire
Speed Rating "Y" = 186mph (300kph)
Traction: A
Temperature: A
540 A APrice: $164.00 (each)
Qty:
012345678Includes Manufacturer's Road Hazard Warranty
Rear: 285/35ZR19
Serv. Desc: 99YLoad Index 99 = 1709lbs (775kg) per tire
Traction: A
Temperature: A
540 A APrice: $277.00 (each)
Qty:
Set of 4: $882.00
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
