Adjusting NPP valves to be just partially open
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
For less than $1 and including the 4 bnuts and four lock washers for the u-bolts; just installed them over the rods to hold flapper ~25% open when running ( sounds just about right to me). Adjusting is a simple case of loosening the nuts and sliding the u-bolt one way or another.
My question, is there any risk or possible damage by keeping the flapper always partially open???![Confused](https://www.corvetteforum.com/forums/images/smilies/confused5.gif)
Frank
Frank
![](/forums/images/ranks/4k-5k.gif)
The kit with split stainless steel collars and the extra long allen wrench is well worth the money. And you can remove them anytime in the future to restore the system back to original. Keeping the valves open slightly, say 1/4 inch, provides a nice exhaust note, with nifty gurgeling and poping while deceleating down through the gears; so much cooler than pulling the fuse, and so much more considerate to your neighbors.
The idea here is to block the valves partly open without needing vacuum on the valves.
This is one option from my junk drawer http://forums.corvetteforum.com/1578279839-post10.html but the idea above to use a couple of U clamps is a better idea.
![](/forums/images/ranks/2k-3k.gif)
thats exactly my thoughts and experience............
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Frank
http://s1192.photobucket.com/albums/aa323/frankmp/
![](/forums/images/ranks/7k-10k.gif)
Received 3,099 Likes
2021 C6 of the Year Finalist - Modified
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_marine_corp.png)
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/stjude15.jpg)
Sheesh .......................... For all that nonsense, I'd just go ahead and buy the kit from Talon. How much gas and wasted time trying to chase the darn collars down. Besides which, what ever happened to supporting our forum vendors first !
Frank
Talon wrote that he closed down his retail business ... so, how is anyone going to buy these collars from him?
________________________________________
"Greetings all. I just wanted to get this out on the forum a little early so that more members would have a chance to see it. As of the 8th of September I will no longer be a supporting vendor on the Corvette Forum".
http://forums.corvetteforum.com/c6-c...g-up-shop.html
Received 2,515 Likes
St. Jude Donor '15
"In honor of jpee"
september, september...still can buy collars from talon90. or could have..
NCM Lifetime Member
#35
NCM Lifetime Member
#37
Paul
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
#40
