Antifreeze question.... Dex cool or ????????
#41
![](/forums/images/ranks/11k.gif)
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I've had Dexcool in several vehicles: 2000 Corvette, 2005 Tahoe, 2008 Tahoe, 2008 Corvette, 2008 Silverado. Never had any problems. I know many people with late model GM cars (which means they have Dexcool). Don't know of anyone who has had a problem.
The only place I've heard of problems with Dexcool is on the internet.
#42
#43
CI 1-4-5-8-9-10 Vet
![Crazy2](https://www.corvetteforum.com/forums/images/smilies/crazy2.gif)
There is nothing wrong with Dexcool.
Those lawsuits were misleading. If there was such a problem with it, they wouldn't still be using it and offer a 100K powertrain warranty.
The Prestone Dexcool is also good stuff.
You should use distilled water when mixing any coolant, not tap water.
Now, unless you remove the drains from the block, there will still be about 2 gallons of water in the block after it stops draining from the radiator. So, you want to add 100% antifreeze with no water to fill the sytem in order to achive the 50/50 mix.
#44
CI 1-4-5-8-9-10 Vet
The Corvette has a closed cooling system so you can't power flush radiator doesn't have an opening on it like the regular cars. Just let anti-freeze drain from radiator then add new anti-freeze.
On a regular car you can use a hose open up the cap on radiator and do a complete flush until water runs clear.
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
#46
CI 1-4-5-8-9-10 Vet
Re-fill through the reservoir cap. Now it did take a while to get all of the coolant (about 1.8 gal) into to reservoir - waiting on the thermostat to open /working out the air pockets. But that is not unusual, even in old school cars. Next time I'm going to use the gadget described in post no. 2 in this thread:
http://forums.corvetteforum.com/c6-c...t-air-out.html
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
#47
Just open the petcock and fill at the reservoir bottle with the garden hose and let the engine run until it runs clear.
![Lurk](https://www.corvetteforum.com/forums/images/smilies/lurk5.gif)
I did this on my other car with regular conventional cooling system with opening on top of radiator and petcock on bottom. I used garden water with hose and noticed after doing this in time my radiator ended up with barnicle like crust growing on the inside. It was a brand new radiator. Is it possibe that the hard water did this?
#48
CI 1-4-5-8-9-10 Vet
So you did go throught the plastic reservoir bottle?![Lurk](https://www.corvetteforum.com/forums/images/smilies/lurk5.gif)
Yes, I filled through the plastic resorvoir while it drained out the bottom of the radiator. If you had the white crust, I'm sure it was from the hard water as you mentioned and had nothing to do with the method you used to flush.
Antifreeze is supposed to have inhibitors to prevent the issue with minerals, but who knows. I've seen the white crust in radiators as well on some of my cars in the past but they had lots of miles on them.
You shouldn't have that problem with your '05 as long as you flush every 5 years (or less).
#49
