Would a foam gun save me some time?
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I have been using the two bucket system with Zaino but I was wondering if adding a foam gun would save me some time. Between the connecting and disconnecting of the bottle with the attachment and still having to rinse the mitt with clean water
is it really worth it or it just make things more "fun"?
I was gonna get this one:
Gilmour 75QGFMR Foamaster
Just 39 bucks, free shipping from Amazon
![ROFL](https://www.corvetteforum.com/forums/images/smilies/rofl.gif)
![Rock](https://www.corvetteforum.com/forums/images/smilies/rock.gif)
![](/forums/images/ranks/3k-4k.gif)
It will help save some swirls. I always rinse the car well and then use the foam gun to coat the car and allow it to soak while I get my wash bucket ready. Go back out rinse and then hand wash. So it will add a little time if you do it the way I do but most "pros" recommend it since you are breaking the surface crap that may have been moved around the surface without foaming first. Also helps out big time with starting wheels and exhaust. Even though I have a dedicated wheel/exhaust wash mit it's nice to not have it super dirty every time. Does the one you're looking at allow you to use it to rinse and foam by just flipping a switch? The one I have does and that way I can keep it connected to the hose for the whole process.
I've had two different types of foam guns, the hose mounted Gilmour and a G-foam for the pressure washer. IMO they look really cool but are a complete waste of time and money. If you want the safest way to wash, get a pressure washer with a nice fan shaped end and use that to flush off all dirt before washing. Doing a solid rinse leaves so little dirt in my wash bucket that I can use it on 3-4 cars before the water even starts getting discolored. With the powerwasher you remove nearly all of the abrasive dirt, the only thing left is the road grime film that you have to wash off by hand.
I had that one, but went with a different route
see post
http://forums.corvetteforum.com/c6-c...non-setup.html
see post
CF Senior Member
![](http://images.corvetteforum.com/images/ranks/11k.gif)
I'm not a 'wash & wax' fanatic but IMO a foam gun isn't necessary to save time. Good Lord, the Corvette is a relatively small car...it doesn't take that long to wash and dry it. You should try washing a Suburban or an F250 crew cab truck.
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
I use a little Gilmour setup to pre-soak the car in suds first.
Started this process when we got our Jerez black M3. The paint on that care was especially prone to swirl marks.
Is it helping a great deal? Not really sure, but it is a process that I have gotten use to that does not take any real time.
My neighbors think I am nuts, and that is perfectly fine with me. But, they also think driving their vehicles through scratch factories (car washes) is okay too.
I'm huge on detailing but I gotta tell you. A foam gun isn't going to save you ANY time. The set up and clean up of the foam gun itself negates any time savings. I have a foam gun and don't really use it anymore because of this reason. By the time you setup the gun you could have been washing the car!
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![No No](https://www.corvetteforum.com/forums/images/smilies/nono.gif)
Thank you all for the replies! I guess I'll stick with the two buckets system for now.
