Dash lights-is the "reset" button
![](/forums/images/ranks/7k-10k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Each button has it's own little lamp.
Unfortunately they aren't really designed to be individually replaced.
But, if you're handy with a soldering iron, you can install new LED's.
The "standard' approach is to wait until several of them are out and then replace the switch cluster.
Relatively easy DIY swap and not too expensive.
The entire dash/guage/switch surround snaps off in one piece.
There's one connector for the switches and is a major PITA to get off, so most just remove the entire switch assembly, 3 screws, and a new one is less than $50, IIRC.
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
That's my understanding too.
Especially given the number of reported failures.
The member that posted his DIY bulb replacement used Radio Shack LED's. I think that's all he could find that were small enough to fit.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/100-500.gif)
Anybody have any instructions for DIY switch replacement?
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
