C6 Z06 Tail light and running lights out?
8th Gear
Looking for some help. Have a 2006 z06 and front running lights (orange) and the rear taillights quit working. Fuse # 8 is good but not sure how to check # 38 the big square one. the headlights and break lights work also. Any ideas?
Race Car Tech
If both are not working, it could be a bad micro relay #37. That #38 is the relay for the fog lamps.
You can swap relays to see if #37 is good or bad.
Good Luck
According to my electrical wiring diagrams, it's fuse #8 10A in the engine fuse block for the park/turn signal and fuse #5 15A for the rear stop lights, both activated by relay #37 also found in the engine fuse box.
Good Luck
Good Luck
Had the same issue on my Z, changed fuse and no issues since.
8th Gear
I"ve checked all fuses and switched the relays 37 and 38. no luck. i also noticed my fog lights are not working either. i've got no tail lights or parking lights and no fog lights. The brake lights work and headlights work. Any other thoughts?
Race Car Tech
The fuse #22 (15A) is for the fog lights and relay #38 allows power to the lights.
Is it possible that both relays went bad? It's against the odds of that happening, but one never knows. Were the fogs working before you swapped relays?
I'm looking at the wiring schematic for both the Park and Fog circuits, and there is nothing common except the steering column turn signal/multi-function switch. All the circuits are controlled by the BCM.
I have the wiring schematics if you want a copy of them. They are in a PDF format with all the C6 electrical circuits.
It may help.
PM me your e-mail and I can send them to you.
C6 tail ligts / running lights / flashers not working
The relay #38 is for the fog lights, and #37 is for the park (DRL) lights and rear tail lights.
It may help.
It may help.
When headlights / running lights are on, I have nothing in the rear except for the flashers. I have checked fuse 8, swapped relays 37 & 38, yada yada yada... I am out of state for work and driving around like this.... Just waiting to get pulled over!! Can anyone offer any help at all please? What was your fix if you found one? I am an electrician and have friends in the area that I can borrow tools from if I can narrow it down. I'd also like copies of those schematics please.
Any help is appreciated. Thanks in advance.
Race Car Tech
I am having similar issues. I have the Eagle Eye LED tail lights installed on a 2008 C6. Intermittently / currently I have NO brake lights, no tail / running lights. Right side tails flash regardless of signal chosen, left side tails do nothing at all. Rear side markers work but flash with the right side tails as do the license plate lights.
Schematics
Thanks in advance.
Race Car Tech
Hope the diagrams help you solve the issues.
No Running Lights 2008 c6
It may help.
It may help.
Thank you
Will wwlandry@gmail.com
No runningvlight or side marker driver side only!!!
This thing is pissing me off, i replaced all fuses and still same ****, any help? Its only on the driver side.....
Julio.pelliciercruz@yahoo.com
Race Car Tech
I sent you the schematics via e-mail. It's schematic on page 32 of the PDF It appears that the ground wire is the same for both, so check that. Also, the brown wire is common from therelay, so check your connectors to make sure you have no broken wire there, and that your connector contacts are clean.
Good Luck.
Cruising
Fuse 8 keeps blowing when lights are turned on. Swapped relay with another and made no difference. Everything on the vehicle works except 4 x side markers, 2 x license plate lights and tail lights when acting as running lights. Tail lights work fine when braking/signalling.
I disconnected all four side markers, the two license plate lamps and all four tail lights and the fuse continues to blow when I turn the lights on.
I do not see any visible signs of shorted wires. All connectors appear ok but car is 9 years old and some connectors are showing some yellowing,
Just curious, when the car is turned off and I check continuity between positive and negative on one of the side marker connectors it shows continuity. Is that normal?
Light issue
Mhouser007,
I found that my front driver's side marker had shorted out the circuit. I thought that fixed the problem and it happened again. The harness wiring at the rear driver's side markers had a chafed wire and it was shorting out and blowing the fuse. I repaired the wire and replaced the marker bulbs. My issue was fixed.
There should be an open between positive and negative terminals. I would check each side to chassis ground to find the short. Seems like you have wire chafed in that light.
QUOTE=mhouser007;1604439049]Abe did you figure out your issue. I just started having a similar problem.
Just curious, when the car is turned off and I check continuity between positive and negative on one of the side marker connectors it shows continuity. Is that normal?[/QUOTE]
Cruising
Either side of the side marker connection to ground shows closed circuit. All markers are showing the same thing. Same goes for license plate lights and tail lights. No matter what I connect to ground or each other everything is closed.
Good Luck.
Good Luck.
jrjwong@gmail.com
