C6 ABS Bleed Using Scanner - Our cars are 10+ years old! VID
![](/forums/images/ranks/3k-4k.gif)
Received 1,298 Likes
St. Jude Donor '21
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Brake system parts are expensive and brake fluid is cheap (last time I checked!). With this in mind, is your C6 due for a FULL brake flush including the ABS system?
Here is one way to accomplish this task and sleep a little easier.
Cheers!
T4L
Cheers!
T4L
The following 4 users liked this post by Toys4Life C5:
![](https://www.corvetteforum.com/forums/images/buttons/collapse_tcat.gif)
Popular Reply
03-10-2024, 08:58 AM
![](/forums/images/ranks/11k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Couple takeaways.
1) I like his MaxJack setup,
2) I'm assuming the GM TechII scanner has the bleeding function?????
3) The all elusive 10mm socket
Emergency 10mm Socket Dispenser
![](https://cimg7.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/1435x1600/10mm_socket_dispencer_bc7ff123abd1a7e804fa0889ad1a6ea68b10ac92.png)
Couple takeaways.
The following 6 users liked this post by Mr D.:
07MontyRed (03-10-2024),
Cmccomb1 (03-10-2024),
Dave Carney (03-12-2024),
FatChance (03-10-2024),
HotRod Junkie (03-17-2024),
and 1 others liked this post.
