[Z06] Ls7 Bolt Torque Specs
![](/forums/images/ranks/2k-3k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
These numbers are from one of the builders at Wixom. Sorry it's jumbled up a little, I had to copy it off a spread sheet and it won't keep the formating. Hope this helps.
R/
Jeff
DESCRIPTION TORQUE(Nm.)
CAMSHAFT RETAINER BOLT 25 +/- 4
OIL GALLERY PLUG 60 +/- 10
INNER MAIN BEARING CAP BOLT 20 (+/- 4) + 80 deg (+/- 3 deg)
OUTER MAIN BEARING CAP BOLT 20 (+/- 4) + 51 deg (+/- 3 deg)
MAIN BEARING CAP SIDE BOLT 25 +/- 4
CRANK SENSOR BOLT 25 +/- 4
CONNECTING ROD BOLT 20 (+/- 3) + 110o (+/- 3 deg)
TIMING CHAIN DAMPER BOLT 25 +/- 4
CAM SPROCKET BOLT 30 +/- 4
OIL PUMP BOLT - PRECONDITION 15 +/- 3
OIL PUMP BOLT 25 +/- 4
FRONT COVER BOLT - PRECONDITION 15 +/- 3
FRONT COVER BOLT - FINAL 30 +/- 4
REAR SEAL HOUSING BOLT - PRECONDITION 15 +/- 3
REAR SEAL HOUSING BOLT 30 +/- 4
OIL DEFLECTOR NUT 25 +/- 4
OIL PAN BOLT - M8 - PRECONDITION 15 +/- 3
OIL PAN BOLT - M8 - FINAL 25 +/- 4
OIL PAN BOLT - M6 12 +/- 2
LIFTER/GUIDE ASSEMBLY BOLT 12 +/- 2
VALLEY COVER BOLT 25 +/- 4
ROCKER ARM BOLT 30 +/- 5
VALVE COVER BOLT 12 +/- 2
INTAKE MANIFOLD BOLT 10 +/- 1
OIL PRESSURE SENSOR 35 +/- 5
CYLINDER HEAD BLEED TUBES/PLUGS 12 +/- 2
WATER PUMP BOLT 30 +/- 5
IGNITION COIL BOLT 12 +/- 2
HARMONIC BALANCER BOLT 50 Nm. (+/- 5) + 140 deg (+/- 4 deg)
KNOCK SENSOR BOLT 25 +/- 4
ENGINE MOUNT BRACKET BOLT 50 +/- 10
COOLANT TEMP SENSOR 20 +/- 4
EXHAUST MANIFOLD BOLT - PRECONDITION 14 +/- 2
EXHAUST MANIFOLD BOLT - FINAL 20 +/- 2
TORQUE SPARK PLUG 20 +/- 3
CYLINDER HEAD CORE PLUG 20 +/- 4
EVAP VALVE BOLT 50 +/- 10
LIFT BRACKET BOLT 50 +/- 10
FLYWHEEL BOLTS - FINAL (TORQUE + ANGLE) 30 Nm. + 40 deg
FLYWHEEL BOLTS - PRECONDITION 20 +/- 4
CLUTCH PLATE BOLT - FINAL 70 +/- 7
R/
Jeff
R/
Jeff
R/
Jeff
![](/forums/images/ranks/500-1000.gif)
R/
Jeff
R/
Jeff
Maybe it's obvious, but I wrote a couple of these numbers down (rocker arm bolt and valve cover bolt), not realizing they are N.m and NOT ft-lbs. Just before I installed the rocker arms, I posted requesting some advice and I happened to mention 30 ft-lbs. And a responder said he used 22 ft-lbs. Then one of the engine builders chimed in saying it was 30 N.m. Any way, just making sure that you realize it is N.m.
![](/forums/images/ranks/100-500.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
yes I torqued mine when I replaced them with my CHE rockers. Checked the Chevy engine manual page 9-1099, "Valve rocker arms 30 N-m or 22 lb ft."
has anybody been able to verify the differences between david farmer torque list and the above "wixom" list? Some are different. For instance spark plugs - 20 n.m on the above list. On the DF list it's 15 n.m
Not sure what the conversion to n.m.'s are, but the chevy service manual says the spark-plugs are to be torqued to 11 ft-lbs
![](/forums/images/ranks/3k-4k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Hello All,
I am rebuilding an LS7 Gen IV Aluminum block and connecting rod bolt torque specs are all over the MAP depending where you look.... Anyone have a good GM # or spec?
I have seen 15ft lbs first pass, with 110 degree final angle pass
I have seen 15ft lbs first pass, with 75 degree final angle pass
And Last 15ft lbs first pass, with 85 degree final angle pass
Which should I pick? I would like to get this right the first time kinda important! Not sure why specs are all over the place.
Thanks for any help and suggestions!
Can someone please explain what the + 80 deg (+/- 3 deg) means.
Means get as close as you can to that number plus or minus.
Your goal is 80 deg +or-
So 81 deg is ok and/or so is 79 in that case. 81 being +1 and 79 being -1
But DONT go over 83 deg or under 77.
Hope that helps.
Hope that helps.
