[Z06] wcc 946EXT wheels NIGHTMARE!!!!
![](/forums/images/ranks/100-500.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
So I bought the WCC 946 exts with nitto invos for my 08 z06. Clean install but the dealer said there were no sensors installed. SO I bought the TPM tool myself and started to program them (there WERE sensors installed) and i got a horn chirp from the first three sensors and when i got to the fourth it wouldnt see it and then the nightmare started........now the vehicle wont see any fobs.....there is a relay clicking sound under the hood.....the rear lights are flashing dim of course it wont start and its just going haywire!!!!! I am waiting on a tow right now ill let you know what the dealer says.
![](/forums/images/ranks/4k-5k.gif)
Also a word of advice - before you start to reprogram all your sensors, make sure the batteries in the programmer are healthy! I found this out via a 1/2 hour of frustration ![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
Z//
Z//
thanks everyone....it WAS the battery but the tire pressure sensors still wont work....been to two dealers in San Antonio and still nothing...... buyer beware of West Coast Corvettes and the sensors they "put" in their wheels.
furthermore it says service tire monitor system now and xx's on two wheels......the sensor are VERY incompatible with the car for some reason....i have exhausted every bit of objective insight into the problem and im still stumped!!
![](/forums/images/ranks/5k-6k.gif)
Did W.C.C. mount the tires? That where/ when most sensors are damaged...
Have you tryed trigering sensor through the tire instead of the rim?They are towards the center of the rim on bands if they are WCC rims usually.I had to do that with a set of them years ago.
![](/forums/images/ranks/3k-4k.gif)
I had the same problem with the HRE's - do you know exactly where the sensors are mounted? When they are banded deep in the wheel they can be very hard to pick up - I went through 2 9v batteries while trying to set the sensors. I could get first three to trigger from the standard position but I had to do the last wheel from the inside. You can actually have the wheels unbolted and on the ground in the wheel well to make it easier if you need to. I spent over an hour trying to get the last sensor to trigger.
excellent post rpo! yeah i did try though the tire (sidewall and middle of tread) as well as wheel.....i will try again Monday, it was that last one that wouldnt program just like yours.
I purchased GM wheels from WCC but put stock GM wheel sensors in from my local dealer. These are my track wheels, never had a problem programming them with the Bartech.
I'd try switching to GM sensors.
Good luck
Good luck
