[Z06] Burned up my fan connector ....
yet another example of "you have to pay to play". My cooling fan stopped working .... found out the fan connector was melted. Tech said the APR splitter was blocking too much air flow (80% ... LOL BS) causing the fan to run all the time and melt the connector. Thats BS ... but what is true is that I have a tune (w/ fan ajustment) that DOES cause the fan to run on high almost all the time. I'm almost positive that tune is what caused the connector to melt.
Either way ... if your fan runs too much apparently you will melt the connector. Seems odd that the fan can run long enough to overrun the design of the plug ... Fug ....
