[Z06] WEIGHT vs HP
My 07 3150 lb stock Z @ 505 hp would figure @ 6.24 lbs/hp. My reasoning would be you for every 6 lbs dropped would that be the equivilent of gaining 1 hp? 60 lbs= 10 hp ? drop 600 lbs = 100 hp equivilent? The result could be: would a 3150 lb Z with an LS7 producing 605 crank hp perform the same as a 2550 lb Z with a stock LS7?
Lower weight alway's rules, as the car will perform better in every way, but very expensive to do. To many factor's in the power/weight ratio for a general rule, as low end engine torque, gearing, traction, ext are all big factor's. Clearly the large displacement LS7 has a good torque advantage here, but moving less weight around is even better. HP number's make for good marketing, but some low torque 5000 lb vehicle's, what does it really mean.
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
I have always heard as a general rule of thumb, that for every 100 lbs the car loses it gains approx. .1 tenth in et.
Conversely, every 10 h.p gained is also suppose to shave off approx. .1 tenth in et.
If those rules of thumbs are somewhat accurate, then logically, the above statement may be somewhat accurate, as a general rule of thumb.
Then as a rule of thumb for a Corvette with an iron block and stereo with me in it weighing 3584 race weight, I need another 30+ HP to equal C5s weighing in at 3200+?
If that's all, I am going to order me the Turbonator!!
Jimmy is right. In drag racing we use 100# equals .1 second in ET. We do not have a general rule for HP vs ET as it takes a lot more HP for gains in a heavy car than it does for a light car.
You might talk to Jim at Halltech. He has done some major weight reduction on his Z06. He may be able to tell you the decrease in ET.
You can also model the car in software programs like Quarter or Quarter Jr and then experiment with weight reduction.
I used to race against a guy named Jerry Dunbar. Jerry was faster than the thunders of hell, but, Jerry weighed more than double what I did. The cars were weighed without driver so the cars had to weigh about the same (2,450# to 2,600# depending on engine displacement and type of transmission). Jerry was a great qualifier but all you had to do was keep up with him and toward the end of the race Jerry's tires would start to give up because of the extra weight. Weight matters a lot in road racing. You don't see many fat pro racers. Take a look at the Corvette guys, Ron fellows, Andy Pilgrim, etc. The more weight you can shed the faster you will go. It is simple physics.
Jim
Jim
what i was trying to figure out is how much HP is needed to vercome athe weight diff say a car is 300 lbs heaveir than u so if both put out 500 RWHP how much more wud the car that weigh 300 lbs more need to be equal again
so of 10hp for every 100 lbs means the one car wud have to have 530 RWHP to stay even with the lighter car
Fellas just remember your ratios from school. It is a little bit different for each car/hp rating.
Take a stock Z06 assuming 3200lbs.
Power to weight: 3200lbs/505hp = 6.34 lb/hp
If you add 500lbs to the Z06 you need to refigure how much hp you will need to maintain the 6.34 lb/hp so....
3700lbs/ X hp = 6.34 lbs/hp
do a little algebra and you get approx 583.6 hp.
So 500lbs on a 3200lbs Z06 requires about an extra 78 hp.
So every extra 100 lbs on a Z06 requires about 15.6 extra hp to maintain the same power to weight ratio.
I would say the answer is all relative to what weight you are starting out with. Or in other words, say 200 lbs. will have a greater impact on one car more than another car depending on what base weight you are talking about.
Car #1 weighs 3,000 lbs. and car #2 weighs 4,000 lbs. They both have the same amount of HP and TQ. If you added 200 lbs. to both cars I would say it would have an overall bigger impact on car #1 more than car #2.
Pretty difficult to apply a simple conversion of X amount of HP per X amount of weight fits all.
take the vehicle's weight, divide by BHP - and you have the power to weight ratio broken down to lbs per HP. That's the only formula. It is impossible for there to be one figure that's the answer to everything. Every situation is different. At 3150 LBS and 505 BHP, you have each HP carrying around 6.23 LBS. With the same BHP at 2400 LBS each HP would only be carrying 4.7 LBS. To achieve that power to weight ratio while adding HP alone, you would need a 3150 LB car with 670 BHP.
I think. I'm bad at math. But yea, there is no one answer to this question. The "formula" is just weight divided by power.
Car #1: 3000lbs/ 250hp = 12lb/hp
add 200lbs
3200lbs/ x hp = 12lb/hp
solve for x: x = 266.67 hp. So car 1 needs 16.67 extra hp
Car #2: 4000lbs / 250 hp = 16 lb/hp
add 200 lbs
4200 lbs / x hp = 16 lb/hp
solve for x: x = 262.5 hp So car 1 needs an extra 12.5 hp to maintain its power to weight of 16 lb/hp
This will explain it all.
They start with a light car, lose 100 lbs
then lose 500 lbs
they end up gaining more than .1 for every hundred pounds on this particular car. Although its extreme, you can see what weight does. Imagine this gap on a road coarse, turn after turn, and you'll see why lighter is better!
http://www.hulu.com/watch/228074/car...pped-for-speed
then lose 500 lbs
So here again 6.24 does not equal 6.24 in the real world.
