[Z06] oil pressure at idle ?
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
what should it be ? mine is 28 per the dash digital gauge .i thought it should be 50+. please help
dealer is still dicking around .
![Confused2](https://www.corvetteforum.com/forums/images/smilies/confused2.gif)
![](/forums/images/ranks/4k-5k.gif)
40 and a bit hot and just over 60 cold. Idle. 07 Z06.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![](/forums/images/ranks/7k-10k.gif)
50PSI+ when cold, ~25-30 with oil temp 200*+, even lower at idle when @ 250*.
The rule of thumb is 10PSI for every 1000 RPM.
Per the Owner's Manual, Chevy won't worry at your idle oil pressure.
they wont worry its that low even though i have been in for service for low oil psi warning , and low oil ticket isstill open n this is within the 1000 miles they wanted me to come back in to check oil level.
![](/forums/images/ranks/11k.gif)
At idle, 55 when cold, 45-49 when oil temp is running 160*. 40 when oil temp is 180. 26-30 when oil temp is 210+ after a hard run and coolant is 210+.
From page 3-47 of my 09Z OM:
Oil pressure should be 20-80 PSI. In certain situations such as long, extended idles on hot days, it could read as low as 6 PSI and still be considered normal.
My 06Z would idle about 28-30 psi after a good warmup. Car had 48k with no issues when I sold it last year. The new ZR1 LS9 idles at the same pressure. So from my personal experience, it appears normal to me.
![](/forums/images/ranks/100-500.gif)
1 Post
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
![](/forums/images/ranks/5k-6k.gif)
I watch my oil pressure and gauges a lot... it is hard to put an exact number on the "warm" oil pressure. I was cruising just the other day next to my buddies '08 Z... Mine is a '06.... We came to a stop for a bridge and were chatting... His oil pressure at idle was 28 psi mine was 26 psi... however his oil temp was 201.. mine was 189..... We drove the same route same everything.. his oil temp was higher.. my pressure was lower. You never know exactly from car to car... there is a range and as long as you are in it you are fine....
Premium Supporting Vendor
FYI - AMSOIL's doesn't make a high ZDDP 5w40. The AMSOIL European 5w40 is a good oil for those willing to go against the owner's manual (and AMSOIL's recommendation for the C6 Z06), but this oil complies with European limits and isn't listed by AMSOIL as high ZDDP.
The AMSOIL SAE Synthetic Premium Protection 10w40 (Product Code AMOQT) which has zinc – 1378 ppm, phosphorus 1265 ppm, is listed by AMSOIL as one of their oil's recommended for applications requiring high ZDDP. I used this oil for several seasons in my stock LS6 02 Z06 prior to AMSOIL coming out with a real racing 10w30 which I now use.
__________________
![](http://www.c66racing.com/images/Banner-450x60-C66-Racing.jpg)
![](https://www.corvetteforum.com/forums/signaturepics/sigpic23956_1.gif)
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
