[Z06] what can happen if you were to accidently down-shift to a too low gear?
![](/forums/images/ranks/500-1000.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
what can happen if you were to accidently down-shift to a too low gear while on the race track. For example down shifting into 2nd instead of 4th?
![](/forums/images/ranks/1k-2k.gif)
1 Post
![Wink](https://www.corvetteforum.com/forums/images/smilies/wink5.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
I also hear that on special occasions, sometimes this action can magically create poop in peoples pants!
![](/forums/images/ranks/5k-6k.gif)
If you are lucky, the rear tires will spin a bit and you will slow down since the rev limiter will have cut the fuel supply.
The unlucky part is about the same except you'll be leaving behind a trail of very expensive engine parts.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Can it damage your tranny as well or jus your engine?
1 Post
And like mentioned above, if it's fast enough and fuel cut hits you can save it and nothing happens. Most common thing I've seen happen is spun rod bearings.
Depends. If the failure causes the engine to lock at high RPM I could see it be possible that enough shock could be generated to break something in the transmission or differential. I would think it would be unlikely, though, since if that were to happen the tires would lock up and the car would just skid to a stop.
The actual act of shifting it too far down could also cause damage - syncros can only do so much to match speed.
Especially if you think your power - upshifting from 3rd to 4th and you mis-shift to 2nd. - lots of blame placed on the LS7 when many owners of these blown gems were power mis-shifting
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
Even with the fuel cut, physics still say the motor will turn the rpm, just not under power. Unless you immediately clutch it.
I would surmise that the valvetrain would be the most susceptible to damage, followed closely by the rods.
Was this an actual or hypothetical situation? Just curious if there was any damage.
![](/forums/images/ranks/7k-10k.gif)
bent valves, spun bearing(s) broken push rod...the list goes on
In my C5, I had it tuned with cam/heads..the rev limiter was set up above the OEM setting... and I did what you asked, shifted into 2nd instead of 4th... my motor was fine, but I grenaded the Tranny (T56) and fried the Synchros...
Level IV Tranny Cartek Clutch and about $4,000 later...
![Crazy](https://www.corvetteforum.com/forums/images/smilies/crazy.gif)
