Heads/Cam/intake w/o Headers. What am I giving up?
![](/forums/images/ranks/100-500.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I want to do a stage 3 package (Heads, Cam, Intake, tune) to increase and change the car's power delivery. What I DO NOT want is a louder car.
I have heard the stock manifolds flow pretty well. Would it be harmful to leave them? (vs headers)
I am okay with sacrificing some HP if there are no other side effects.
Same thing here, promised the wife that I was not going to turn this car into a smelly car that gasses us in traffic like my TA. (right away). Will prob do it after I put the catted y pipe on my TA and show her a catted system will not stench us out.
![](/forums/images/ranks/2k-3k.gif)
with this said, I can’t say I’ve ever seen a big HC car on stock manifolds; you should do it and let us know the results!
grinder11 (06-18-2024)
Not sure what year your car is but longtubes with cats and a pre '09 Z catback would be pretty quiet. Something to consider if you don't want to give up any power gains. I ran that setup for a while before going to an '09+ stock catback.
Originally Posted by niphilli2
it really depends on the size of the cam. The stock manifolds are great up to about 550 whp beyond that they become a restriction.
Supporting Vendor
depends on the cam, but it can be worth a lot of power. I won't do it as timing can be so low on pump gas exhaust temps get really hot and can melt OEM cats. Do headers w/ high flow cats, and leave OEM mufflers. In closed mode if you think that is loud than get an old carolla.
The following 5 users liked this post by Cordes Performance Racing:
97TAWS6 (06-30-2024),
Gearbhall (06-30-2024),
NA FURY (06-29-2024),
Noblebro175 (06-29-2024),
pdc001 (06-29-2024)
Brian Thomson made over 1,000 crank hp using an LS9 blower on an LS7 running stock exhaust manifolds. They are very good. Research Thomson Automotive 1000hp LS7 article in Motor Trend in 2015.....
Catted headers with stock NPP isn't loud at all. Hell catless headers with stock NPP is quiet when the valves are shut, but to avoid the smell go catted. The only problem is stock NPP drones pretty bad when the valves are open.
Headers have no impact on the size of cam you can use. You can put as big a cam as you want, its just you won't benefit as much as if you did headers also.
I looked at it this way, if I am choking the cam a bit, I can swap headers easy... if I have to swap a cam because I chose it for stock exhaust and I upgrade to headers.... not so much. Really do not want to redo installs, so choosing the cam to fit my goal of a great street cam based on Tony's suggestion. No buck under 2k etc.. Choking it a bit with stock manifolds for sake of my current goals.
the reality is the reason the LS7 loves big camshafts is because the overlap creates exhaust scavenging that helps with the rather anemic exhaust port flow. Overlap is certainly not going to hurt the stock exhaust if you are willing to deal with the driving manners.
![](/forums/images/ranks/7k-10k.gif)
Received 4,930 Likes
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
