Eforce vs Maggie TVS 2300
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
I kind of wish I waited, got this hood and the Whipple. That said, it remains to be seen if the bigger Whipple heat exchanger does a good job controlling the IAT's. It would also be interesting to see if IAT's on an E-Force would be lowered with a little airflow around the top of the blower.
I really like this one too.![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
If you want to improve your E-Force IATs....run Water Wetter and distilled water only in the supercharger cooling loop...no antifreeze, trim the radiator baffle to let air in, isolate the air filter from the underhood heat (BeeHive), and run a 160 thermostat. If that doesn't get you wher you want to be then you need to step up to a larger heat exchanger. I found a guy who is willing to build em' but I think he may be too pricey (still working this) and you should consider a higher capacity cooling pump. The Bosch pump moves 5gpm...Mezeire makes one that moves 20gpm.
Moderator/Tech Contributor
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,880 Likes
2015 C7 of the Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
$1,200 for the hood plus shipping, painting, & installation. 2K? It sure does look sweet!.
Elmer
Elmer
![](/forums/images/ranks/5k-6k.gif)
That Whipple ain't gonna fit under that hood...unless you bring along a chainsaw!! I haven't seen any photos of the Whipple taken from fender to fender but it has to be standing tall...very tall.
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
I already have the 160 thermostat / DeWitts rad / fan speed adjustment and have the baffle trimmed. The beehive is not on at the moment, but it will be on soon. I'm already at 70/30 distilled water to A/F. I've used water wetter before in 2 different cars with no measurable improvement. Can't see any of these things making more than a marginal improvement, but I'm hoping the beehive shows some. I might insulate the bottom of it before I put it on.
I have uncoated headers which is probably making it worse.
The overall system water capacity is probably too low, and pumping the hot water around faster probably won't help. I'm starting to think the intercooler end is also too small, particularly with the top of the blower just about against the hood. I do wonder if a higher hood allowing some airflow would help. Maybe I'll take my hood off one day and drive around.
I'd love to have a bigger H/E & bigger tank, but I'd like to see it work before I spent the coin. Same with the chiller setup. I'm not looking to make a pile more power, I just want it to handle what it has better. I would be interested in meth too, but just for safety. I saw on one post that Engand Green may have done an after blower setup for E-Force but have not contacted them yet.
It has not even gotten really hot here yet and I'm seeing sky high numbers just driving home from work and hitting a little traffic with no dipping into the boost.
![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
I was wondering wonder how tall the Whipple is, but have not seen any measurements or recommended hoods.
It has not even gotten really hot here yet and I'm seeing sky high numbers just driving home from work and hitting a little traffic with no dipping into the boost.![Ack!](https://www.corvetteforum.com/forums/images/smilies/ack2.gif)
I don't think a vented hood will make much difference....it just looks cool.
Methanol would not help your temps in "off-boost" driving
If you really want a shocker...measure IATs on a bone stock car in traffic or sit still for 5 minutes with a fully warmed up centri on a hot day with the hood shut!
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
Tell me a little about your daily drive and what temps you are seeing. Are you in stop and go traffic or ???
If you going with new hood, then go with Whipple, best PD S/C.
Believe it or not, bigger is not necessarily better when you're talking p/d blowers. A 2.3L blower spinning fast enough to make 8psi will out perform a bigger blower spinning slow enough to "only" make 8psi. Sure the bigger blower is capable of numbers that mean you have to upgrade everything from the front bumper to the rear licence plate. For those guys, you have my attention and admiration. I love to read about your exploits, but have no desire to play along.
It does "look" good though. I wonder how it will look under an a/m hood. Looks to be taller than a Maggie TVS. That means the hoods that will work with the Maggie won't work with the Whipple. Then you get into the "how much is enough" debate. These days folks scoff at 600 wheel like it's a walk in the park to own and maintain. It ain't. The Maggie or EForce can make enough power to shatter most any stock short LS2 or 3. Despite what you read here, not everyone wants 800+ p/d rwhp for their daily driver. Sounds good when you say it real fast though
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
Justin pretty much did say, that unit is very much like the Camaro unit and I've been watching the success of the Camaro version from day one. Every customer has been super happy. That's my gauge of measuring the Corvette version. Secondly, knowing background of Whipple, I know they release top quality product. They're waiting for some paper work to finalize.
Supporting Vendor
The price is $1200 from supervettes.
http://www.supervettes.com/ss-vette-...nvertible.html
Wonder if it will fit the maggie.
#33
At the moment you are drawing hot underhood air to feed the engine. No single one of the items I mentioned above is the "Eureka" answer but the combination of all of them is working for me. The Beehive plus the trimmed shroud will make a difference. You effectively create a CAI system with those two changes. The reality of a supercharged car is at low speeds you simply are not moving much if any air across the heat exchanger/intercooler. This is true of both PD and centri cars. In a perfect world you'd have a heat exchanger with fans to pull air across at low speeds like the Mustang guys are using.
If you really want a shocker...measure IATs on a bone stock car in traffic or sit still for 5 minutes with a fully warmed up centri on a hot day with the hood shut!![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
To the OP, sorry for the hijack!
#34
Supporting Vendor
#35
![](/forums/images/ranks/4k-5k.gif)
I have approached kincaid performance about doing a "killer chiller" setup for the C5/C6 platform, hopefully they will take it up with all the new found PD blower interest in the corvette community and the fact is, they need it. cooling IAT's 50 degrees on the vette systems would be great.
#37
![](/forums/images/ranks/3k-4k.gif)
Oh, yeh... that ZR1 Extreme Hood looks great. Not sure how it would look on a Z06/ZR1/GS with the stock air inlet. Might be too much.
I also like this SV4 hood from Lingenfelter...
![](http://www.grandsportregistry.com/images/SV4_hood-300.jpg)
#38
![](http://i270.photobucket.com/albums/jj91/ChomperDog/sv4hood1.jpg)
#39
#40
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
I'm finding out if the MFG would install a large vent in the rear of the hood. I would think it's a pretty easy job and if done right would not compromise structural integrity... If they would then this hood would be about perfect for exhausting hot air while looking pretty sexy!!
