silicone grease on weatherstripping
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
The owners manual on my 2006 coupe suggests using silicone grease on rubber weatherstripping to eliminate squeaks. The closest thing I can find--after going to an auto parts store, Home Depot, Lowes, and Ace Hardware--is Gunk Liquid Wrench Silicone Spray. Label states suitable for rubber, wood, plastic, etc. Label further suggests that product be applied by spraying onto cloth and then applying to area. Is this product equivalent to silicone grease?
Moderator
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 3,695 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
But if you want the grease, you can find it here
Originally Posted by johnodrake
I can't say if it equivalent, but I have used it for years with good results.
![](/forums/images/ranks/3k-4k.gif)
However, the best stuff I have found is Gummi-Pflege, available at BMW dealerships and online.
![](http://www.unofficialbmw.com/images/all_gummi_pflege.gif)
Lango (06-15-2024)
![](/forums/images/ranks/4k-5k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
Weatherstrip Lubricant GM part # 36334770
Dielectric Silicone grease GM part # 12345579
CorvettePartsBob is offering GM stuff at his cost til the end of Oct.
Something about a new grand child!!!!
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![cool](https://www.corvetteforum.com/forums/images/smilies/coolgleamA.gif)
![Party!](https://www.corvetteforum.com/forums/images/smilies/party.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_army.png)
Dielectric silicone is available in tube form at any auto parts store. Even better, go to any dive shop or resturant supply store and buy non-toxic silicone. Stay away from spray silicones-too messy.
Originally Posted by AndyF-Dallas
How often should the weather strippings be "greased"????????
Regular old silicone spray works just fine. Unless you have really bad hand eye coordination it is very easy to spray the seals. Wiped off any dripping with a rag and your done. Takes about 30 seconds for both sides.
![](/forums/images/ranks/100-500.gif)
If you use the spray (Ams oil has a good one I use everwhere but the bedroom) just spray it on a cloth then wipe it on! No mess and no worries about using to much.
![](/forums/images/ranks/7k-10k.gif)
I have used the GM silicon(e) grease on my C5 for years. Twice a year, stays put much longer than the aftermarket silicone sprays. My weather strips are like new!
I use the Permatex dielectric grease on my other cars. Same as the GM, just a touch thicker.
![](/forums/images/ranks/11k.gif)
Received 2,090 Likes
St. Jude Donor '13
Wow, a 7 year old thread back from the dead!
But...
I use the dielectric silicone grease annually on all our weatherstripping, except the rubber (and metal) parts that can squeak on the targa top. GM now recommends Superlube Paste (not the spray!!!) on those, and I've found it works much better. It leaves a slight whiteish residue after a while, but works better at quieting the noise and lasts longer.
But...
