Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Bleed Your Hydraulic Clutch
Step by step instructions for do-it-yourselfers.
Bleeding my clutch
St. Jude Donor '08
http://www.rangeracceleration.com/Launch_Tips.html
this is all you need to know look everything over
Mike
Mike
The bleed screw is on the slave cyl and almost impossible to bleed while the car is together. The turkey baster method is to replace the fluid not necesarily bleed air out of the system. I don't know what you are trying to do but if you take it apart, install a $40 bleeder.
Former Vendor
St. Jude Donor '08-'09
i can't believe the slave cylinder is soo hard to access on this car,, is it really that bad? what about from under the car? turkey baster wont get air outta the system...
-carl
-carl
The bleed screw is accessible through a hole on top of the bell-housing. It is not impossible to get to, but it is difficult.
If you can manage to reach the bleeder, than you can also manage to install a remote bleeder, which is a much better use of your time. All subsequent clutch bleeds will be a snap.
This thread has more information on remote-bleeder installation with the driveline in place:
http://forums.corvetteforum.com/show...remote+bleeder
This procedure is actually in the shop manual.
There is another method for getting air out of the system, by vaccum bleeding. Basically you use the Motive cap or something similar, but instead of putting in fluid under pressure you pull a vaccum and (in theory, at least) the air bubbles come to the top.
And most causes of air in the system involve a recent or upcoming trip to the clutch slave, anyway.
I'd suggest to anybody contemplating a clutch job to install a remote bleeder while he's at it. It makes subsequent bleeds (for any purpose) ten times easier.
