RPS Twin Disc clutch problem pictures
![](/forums/images/ranks/100-500.gif)
2016 C6 of Year Finalisof Year Finalist
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I bought an RPS BC2 and installed it in June this year, the clutch worked fine for the last couple of months until I tried to tune the car on nitrous. The first time the nitrous turned on it blew through the clutch so I pulled it out and found the clutch to be completely worn out.
My car is a full weight F-body 3800lbs with driver and puts down 553hp 506ft-lbs to the wheels on motor with 4.10 gears. My nitrous set up is direct port .026 nitrous jets .020 fuel (200 shot to the wheels) I spoke to Rob from RPS in the spring and he assured me that the twin would be fine for my application. Since the install I have only driven 2000-2500 miles and less than 10 runs at the drag strip. I have mostly just autocrossed all summer and when autocrossing I start out and just leave it in 2nd.
I spoke to RPS and they said they wanted me to measure the disks and take pictures, so here they are...
flywheel measures .033" to bolt head
pressure plate .038" to rivet
Inner disk .294" thick
Outer disk .285" thick
floater disk .293" thick
![](http://i835.photobucket.com/albums/zz277/NandJRamos/th_RPSBC2001.jpg)
![](http://i835.photobucket.com/albums/zz277/NandJRamos/th_RPSBC2006.jpg)
![](http://i835.photobucket.com/albums/zz277/NandJRamos/th_RPSBC2005.jpg)
![](http://i835.photobucket.com/albums/zz277/NandJRamos/th_RPSBC2004.jpg)
![](http://i835.photobucket.com/albums/zz277/NandJRamos/th_RPSBC2003.jpg)
![](http://i835.photobucket.com/albums/zz277/NandJRamos/th_RPSBC2002.jpg)
Rob got back to me yesterday and said
Thank you for the pictures and info. Every second gear start in a
3800lb car is equal to 2-3 first gear launchs at the drag strip. Also
I am not sure if you are using the clutch to help rotate the car while
autocrossing, but anytime that your foot is pushing in or out the
clutch pedal the clutch is wearing. To get longer life out of the
clutch, if you are using the clutch to rotate the car be sure to cool
down the clutch after each run by leaving the clutch pedal pushed in
with the engine running so that air can circulate around the disc and
floater. If you do not cool the clutch after each run it is the same
as leaving your foot on the brake pedal after your run. From what I
see and read, the clutch needs a rebuild. A rebuild lists for
$1,795.00 but I give you the racer price of $1,436.00.
Kind regards,
RJ
Kind regards,
RJ
so then I replied: Really the clutch is smoked? I had 7 autocross events this season and the first 2 events of the season were on a slipping tex oz700 with 10000 miles on it. I dont use the clutch at all except to start off so are you telling me that I wore out a $2000 clutch in 5 autocrosses and 10 drag strip passes and only 2000-2500 miles! And all you are going to offer me is -360 on a rebuild?!?!
It just doesn't seem like I got much use out of the clutch that I was told would perform so well!
Jason
Jason
Sorry that was lengthy
my last response was sent yesterday, and havent gotten anything back from them. I just wanted to get all the facts out there.
![Crazy](https://www.corvetteforum.com/forums/images/smilies/crazy.gif)
Former Vendor
I have the RPS triple carbon clutch, two season over 20 drag passes + street use took it apart still looks like new. 9.70 @157. 950rwhp 987rwtq. Maybe talk to them about upgrading to a triple.
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Those carbon clutches are supposed to stay longer than any other...surprising!!!
Christian
Christian
![Confused](https://www.corvetteforum.com/forums/images/smilies/confused5.gif)
![](/forums/images/ranks/5k-6k.gif)
Kind regards,
RJ
Kind regards,
RJ
I've taken a brand new, broken in clutch, [not rps] to the strip and had it slip on the first pass with no refund.
could it be a shim problem? i remember seeing a thread on here a few weeks ago where the clutch manufacturer recommended installing a shim, but in reality that shim was causing the clutch to slip under load....
Djack.....
Twin RPS carbon, same issue, but on a non raced C5. Less than 6000 miles of normal road driving and in less than 12 months it is shot? Keep me inyour loop.....I'm very interested where this goes.
