ZO6 Oil Cooling Lines Connection to Cooler Removal Question
I am removing my oil cooler lines to deal with a leak, in an '07 ZO6.
Do you know, or know a source, for the size of the coupling connection between the line and the oil cooler? Maybe 1"?
Any suggestion on what type of wrench to remove with, with consideration to the tight quarters doing so?
I was able to remove the top line, but the bottom line is more difficult.
Thank you for any thoughts.
This explains it. There may be a black plastic piece over the connection, just pop it off and slide it down the line to access the clip. https://www.youtube.com/watch?v=SsX9ciELVLE
For historical purposes, if anyone else need the answer that worked for me. I used a 1" crow foot to get them off, and presumably the same to tighten them up after replacement or rebuild of those lines.
