Creaks & Groans
Creaks & Groans
I was just reading the Motor Trend comparison of the Vette vs. 911. Talk about bias & sensationalism at it's best. I was throughly disgusted w/the writer & Motor Trend.
Anyways, I did notice something that has validity to it. I have had a few Corvettes starting w/the C4. I have always been annoyed by the noises the car make when going on an angle into a driveway. I blamed the C4's inferior structural integrity for this.
When the C5 came out, all of the talk was about how the structural integrity was improved & no more creaks, groans, rattles, etc. Although mine was rattle free(compared to the C4), it was still creaking & groaning going into my driveway.
I like to ask the C6 owners if their cars suffer from the same thing. I also want to know what causes this & if there is more to this, because the C6 is supposed to be one of the tighest cars out there. So what gives?
My bet is it is from the balsa wood-composite sandwich floor material that is rigid, lightweight, and strong used in concert with the Hydroformed frame rails are most likely the culprit IMO. If and when they go to a more rigid material in the future that will disappear. I may be wrong but that is one of the future technologies slated for the Corvette.
I dont have anything rattling. I do get a little creak out of the center console when entering my driveway or going over speedbumps and that sort of thing. I can make it creak by putting my weight on it. Thats the only noise I have so far.
My car is as tight as a drum. There is some creaking that occurs when I turn into the driveway from the street, however I was successful in isolating the noise. I opened the hatch and repeated the exercise and sure enough, the noise disappeared. I saturated a towel with silicone spray and applied it to the rubber stripping and the noise disappeared. It's the only time I hear this creaking type noise. BTW, Porsches, Lambos, BMW's and Ferrari's have rattles. Just check their forums and you will see owners of $170,000 cars complaining about sqeaks and rattles; and in the case of Lamborghini, weak clutches that fry on command. I believe there is a direct relationship between how stiff the car is sprung and the tendency for noises. They are after all high performance cars.
I drove a buddy's 03 vert w/26K miles this afternoon, it was night and day different from my C6. It was noisier, had more rattles, and didn't feel nearly as glued to the road. Mine is a Z51, his is not. The only rattle in my C6 is the parking brake button, it buzzes every once in a while.
Mine just started rattling from somewhere in the back of the car. I notice it most at low speeds on choppy road surfaces. It sounds like the deck lid is ajar---which it is not or a loose cargo tray---plastic or some non-metallic noise. I have yet to isolate the exact location but is seems to be coming under the trunk. Anybody experience this or have any suggestions? My first Vette is beginning to sound like one of my Trans Ams of the 70's.
I had creaks and groans. I had a BMW 5 series that was famous for creaks and groans from its door seals. This is stuff we used on seals called gummi pflege which is a seal lubricant. I have used this on all the seals on my C6 and the noise has gone away. I reapply every month.
Seal Lubricant
Seal Lubricant
Seal Lubricant
Seal Lubricant
No sounds comeing from my f55 , with 1700 miles so far.
Hope this helps!
PvK
