Hood Stinger
![](/forums/images/ranks/2k-3k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_air_force.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Does anyone know who makes the vinyl for the OEM C7 hood stingers as ordered from the factory? Is it 3M or maybe Avery? Both are big suppliers of vinyl wraps etc.
thanks in advance - tom
kenownr (05-09-2019)
Wrap vs die-cut vinyl are kinda two different animals. I haven't identified what exact material they are using for OEM, it's on the thick side. I'd put money on it being an Oracal or 3M product though.
If you're going to do this install yourself, I recommend going more of the wrap method using something relatively easy like an Avery SW900, with 3M knifeless tape. Lay the knifeless tape around the body line, lay the wrap material (which is much more forgiving than super-sticky cut vinyl), and then cut the excess. You can find some youtube videos on it. If you're going to get a precut vinyl for it, that works fine too, but need to really evaluate your experience with this stuff first. It's not quite as easy to stretch, heat, and manipulate to get it to lay flat without bubbles, especially when your edges are already precut.
My side gig is vinyl graphics.
Here's a video of somebody doing it with knifeless:
The following 3 users liked this post by rogue3standingby:
rogue3standingby (05-09-2019)
Thanks for all your help -- I really appreciate your time linking the video -- neat stuff
tom
I pretty sure I'll got with a professional installer - then I can Bitc** at somebody other than me
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
Moderator
Received 3,834 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
If you have the factory exposed top, have a reputable shop do stinger in a say Vivvid glossy carbon or maybe the 3m... the factory stinger is kind of dull like a carbon flash matt finish... Just my 2 cents Knifeless is way to go for sure
<deleted>
Moderator
I would say anything better than the factory stinger stripe.. everyone has opinions I am respectful of that/
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 19,976 Likes
'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/cf-stjude20.jpg)
That knifeless tape is some very slick stuff. Sure helps to not run the risk of having knife marks left on the painted surface.
Moderator
I do have to say, on my Hayabusa I have real Carbon Fiber Twill frame covers. I used vivvid carbon fiber to wrap the small part of frame that was exposed and damn.. you would have to get like an inch away to tell the real carbon from the vivvid. Even then you would be hard pressed to tell. I know for my experience using it as an actual wrap like a frame it's simply amazing stuff . I do not have any experience how it would be on a hood when used as the stinger.. but the stuff has been great for me.
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
After many hood episodes with knifeless, to be on the safe side make your starting point at both ends of the vinyl. And, when going with the wet approach be careful the vinyl movement doesn't dislodge the knifeless tape.... very difficult to reset at this stage of the game, can easily ruin your project.
Gixxerman (05-09-2019)
![](/forums/images/ranks/3k-4k.gif)
This is what I used on my hood. Good quality material that fit perfectly and very easy install using the wet method. The carbon flash matches the hood louvers perfectly.
https://www.ebay.com/itm/2014-2015-2...-/381647642113
kenownr (05-10-2019)
The following 3 users liked this post by guido7834:
![](/forums/images/ranks/5k-6k.gif)
![](https://cimg5.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/e1e654d0_f9de_4614_a9cf_9324b9ecdb0d_ae50c97f60bd48ee84abea64ae2ce02fd082c65e.jpeg)
![](https://cimg6.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/498800c1_a58b_4cf2_a445_b26c94d045b3_d8c1dd5321855ae0f57cee4584b76a8633ab938c.jpeg)
Did mine to cover up some graphics til i paint..precut by hand 3m something..vinyl..
c3 stinger..3 d flames still show thru..im happy not perfect
kenownr (07-05-2019)
