C7 Z06 vs. Z51 transmission coolers
Scraping the splitter.
There is obviously much concern about how GM will control tranny temps on the C7 Z for those that are outfitted with the A8. Tadge has stated that they are trying to maximize cooling.
Z51 transmission cooler:
Z06 transmission cooler:
Note that this one appears to have the same fan setup as the Z51, and obviously is a larger core.
Apparently, the same core with a different and larger fan setup:
Not sure if this is the same cutaway car and they changed out the fan or if it is a second car.
S.
S.
Snorman,
Interesting photo layout, thanks for posting! The A8 cooler is clearly larger and the different fan setups are interesting. I presume the last photo is probably the A8 specific fan or otherwise maybe some testing is looking at a fan dominant setup (the last photo) which would provide more cooling at lower speed but I wonder if the smaller Z51 fan actually allows more air flow at high speed since much of the cooler can breath freely without being blocked by the shroud.
In any case it is good to see they are addressing this because it will be embarrassing if the transmission goes into protective "limp mode" too quickly in a track oriented platform.
I'm curious too. The bigger fan/shroud appears to more fully cover the core. I hope that's the one they'll be using, lol.
S.
S.
One way to minimize heat is to reduce the amount of time the converter clutch is unlocked. Tight control of the clutch packs used for gear selection along with sufficient pressure will minimize heat there. Avoiding fluid pickup problems with the resulting aeration of fluid is critical. Hopefully the A8 will reduce heat generated in addition to having better cooling. Once the car goes into production it won't take long to find out how hard it can be pushed.
McCarthy1986 (05-26-2020)
I hope that A8 is an oven and that GM builds heavy duty cooling. Thanks for the pics, it does look like they are working on it. Keeping fingers crossed that all that will be transferred to the M7 making it an ice cold performer. If not, I presume it will be easy to buy and swap.
Yes, the last photo is of the cooler on the A8 tranny.
Good info. I do not believe the stock c7z will be able to be run hard for more than about 10 minutes (on a demanding track) before the temps go up for engine and trans fluids to unacceptable levels. Hope I am wrong.
If true, shame on GM. I hope that not to be the case. This concern is well known, both outside and inside GM. It's not rocket science. Engineer to reduce heat generated and engineer to dissipate what heat is generated. It can be done.
If the car can't do this then its a failure.
