C7 Z06 DSX flex fuel kits available
Former Vendor
Just wanted to give everyone a heads up that the C7 Z06 flex fuel kits are available and in stock, ready to ship over at www.dsxtuning.com. These are the originals. They're made using 316 stainless tube for a great appearance and awesome corrosion resistance. The wiring harness is super easy to deal with as well. I promise this is the easiest install there is because it uses true push connect fittings instead of a backing nut to hold the fitting onto the fuel rail. Just snap and go!
If anyone has any questions, don't hesitate to ask!
Not seeing the C7 kit in the attached link. I had one of these on my Gen V. Worked very well for what I used it for. Any way to take this setup with your controller, add lines and rails and use to do a "piggy back" port injection solution with prepped intake?
Former Vendor
I think you're thinking of the fuel pump kits. I don't have a C7 setup yet, but as soon as I have a car to do some fit up, I'll release a system.
Former Vendor
Supporting Vendor
The only flex fuel kits we use!
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
Works great in my C6.
Dem gains tho?
CPR is putting my DSX systme in as we speak!! Can't wait to get it back on Friday.
Former Vendor
