2015 C7 Z06 Clutch Replacement
2nd Gear
I'm fairly certain the clutch on my Vette is on it's way out as it's exhibiting all the typical symptoms of a bad/worn out clutch.
My Vette is a manual 7-speed, and I'm curious what's the average price to replace the clutch on my car? Also, does anyone have the OEM part number for it? I can't seem to find it online.
TIA!
TIA!
Received 9,040 Likes
TIA!
TIA!
https://www.cultragfactoryparts.com/...h-and-flywheel
https://www.cultragfactoryparts.com/...draulic-system
Figure at least $1000 labor to change the clutch.
Bill
Curious how many miles you have.
spen625 (12-25-2022)
believe the clutch is fairly labor extensive, definitely would call a few places to gauge a range of what they are quoting just for the time to replace items not even the parts needed.
yeah what miles and what symptoms are you having? assuming slipping/spiking rpms instead of putting power down?
