C8 General Discussion The place to discuss the next generation of Corvette.
C8 Rendition-What I think is under all the Camo
Old 12-19-2017, 05:54 PM
firstvettesoon
firstvettesoon's Avatar
Received 1,906 Likes on 750 Posts
Originally Posted by K.I.T.T.
um....not....
The side scoops are fabricated under the camo, they go way further back to the quarter and are angled. The front end is much more radical in angular shape and you're way off on the hood.
I've seen the car...just sayin.
Yeah...I posted a pic of the mule with some outlines suggesting that the nose and around the headlamps is sculpted aggressively.
I also see camo paint on the rear deck where glass "should be".
...is this warmer or colder?
Old 12-19-2017, 06:48 PM
Waytofastvette2006
Waytofastvette2006's Avatar
If this is the car I’m buying the first year. Defiantly going to get the extended warranty for sure dont need a feiro situation charge me more but make it look EXOTIC with a DCT transmission
Old 12-19-2017, 07:48 PM
live2drive
live2drive's Avatar
I think you are close and that the ME will look very Ferrari-esque, like these 488 GTs.
Old 12-20-2017, 10:04 AM
RapidC84B
RapidC84B's Avatar
Received 13,416 Likes on 6,107 Posts
Nice! I love all the excitement of a new generation.
Old 12-23-2017, 11:43 PM
firstvettesoon
um....not....
...any closer ? warmer or colder?
The following 2 users liked this post by firstvettesoon:
DickieDoo (12-29-2017), dmaxx3500 (12-25-2017)
Old 12-24-2017, 01:08 AM
JD ZR1
JD ZR1's Avatar
Warmer! Looks great!
firstvettesoon (12-24-2017)
Old 12-29-2017, 04:42 AM
Larshelt
Larshelt's Avatar
Great renders. Look at the bottom picture under the camo. From the B Pillar back, it doesn't appear to be any side class or maybe it's covered up. That appears to change the way the rear class looks. Thoughts?
Old 12-29-2017, 07:05 AM
Z51JEFF
Z51JEFF's Avatar
Don’t be surprised if under all that camo is a Cadillac. It’s widely known Chevrolet had to share the architecture with Cadillac in order to share the cost of developing the car. Compare this picture to the cold weather testing picture and the cars are 2 different cars. But I do like the looks of this car through the camo covering.
Old 12-29-2017, 02:52 PM
firstvettesoon
I agree, but cutting the window line straight at the B pillar would look odd to say the least. I am hoping the window line follows thru to the rear in some very pleasing way.
We need more hints ! But until then...
elegant (12-29-2017), Larshelt (12-29-2017)
Old 12-29-2017, 03:46 PM
DickieDoo
DickieDoo's Avatar
I can only hope it looks as nice as these drawings ! You've done a commendable job in de-cam'oing the pictures.
Old 12-29-2017, 05:45 PM
elegant
elegant's Avatar
Received 2,682 Likes on 1,232 Posts
I totally agree that without the window line continuing rearward and past the B pillar would look odd (in fact I “bizarre” is how I would describe it). I believe that this will be one of the C7’s design clues that will deliberately carry over to the mid-engine C8.
Old 12-29-2017, 05:52 PM
elegant
elegant's Avatar
As to Larshelt’s comment above that it does not look like in the McDonald’s ME pictures, that “From the B Pillar back, it doesn't appear to be any side class or maybe it's covered up,” a single thickness of sticky-back, camo wrap could easily hide any glass. I do agree however, with his last part of his post, e.g., maybe it’s covered up.
Old 12-29-2017, 09:16 PM
  #33
Larshelt
Larshelt's Avatar
I agree with both you and elegant, it wouldn't flow as good as what you have rendered. It would look a lot like the B pillar on the yellow Ferrari 488 below.
The following 2 users liked this post by Larshelt:
elegant (12-29-2017), JerriVette (02-17-2018)
Old 12-30-2017, 01:52 PM
  #34
PurpleLion
PurpleLion's Avatar
[QUOTE=live2drive;1596213600]I think you are close and that the ME will look very Ferrari-esque, like these 488 GTs.
[/QUOTE
The Ferrari is of course beautiful, but, to a large degree, its shape is determined by aerodynamic requirements. Hopefully, GM will follow the same path and design an aerodynamically functional shape that is also beautiful. As opposed to Lamborghini which often designs a shape for impact while ignoring its aerodynamic properties.
Old 12-31-2017, 03:10 PM
  #35
Gonzo
Gonzo's Avatar
Very nice work. It looks a boxy to me. I think the top of the rear vent should stretch and sculp itself across the top of the door and into the top of the front fender. It needs to be more connected. Front to rear. The car not your drawing......
Old 01-01-2018, 07:11 AM
  #36
Rkreigh
Rkreigh's Avatar
try removing the two center posts in the middle of the grill, I don't think the red nose in the pic has that. Soften the lines a bit, it's a winner!
Old 01-01-2018, 08:56 AM
  #37
FrankLP
Miles of Smiles
Support Corvetteforum!
FrankLP's Avatar
2016 C5 of the Year Finalist
Actually... it looks like there are two supports (see the two circled areas in yellow below).
There looks to be two posts, and/or two more substantial angular supports. Perhaps these are temporary at this point... maybe some (or all) are part of the mechanism holding the entire fascia for painting... but there does seem to be some type of middle supports there.
To C8 Rendition-What I think is under all the Camo
Old 01-01-2018, 10:11 AM
  #38
firstvettesoon
Yes. Very hard to make out. The REAR fascia can be seen behind it and also confuses the issue... but we can see the rear profile fairly well straight on with a heavy angled chamfer at the top of the rear fenders.
Take a look at the overlay below. I see a bunch of structure (note the B&W painted camo under the black tarp) in the "grill" area, so the front of the car should be very interesting, especially considering the headlamp area also looks very sculpted.
Old 01-01-2018, 11:11 AM
  #39
Shaka
Shaka's Avatar
Received 1,331 Likes on 790 Posts
I hope they are temporary. Out of these spy photos, I produced these drawings. Obviously there is some guess work but I think it is close. I hope the rear glass is like C5 and 6 just for visibilities sake. If it looks like my dwgs., I'm afraid it is bloody awful. Note the two different designs of the rear vents(grilles) One is a wrap around. See dwg.
Old 01-01-2018, 01:49 PM
  #40
RedLS6
RedLS6's Avatar
Received 1,759 Likes on 796 Posts
Nice sketchwork.
The following 2 users liked this post by RedLS6:
dmaxx3500 (02-17-2018), Shaka (01-01-2018)
Quick Reply: C8 Rendition-What I think is under all the Camo
