What is the maximum change in offsets for 19 X 8.5 and 20 X 11 wheels? I will be keeping stock tires as well.
Can I do +45mm offset front (stock is +52 mm I believe) and +45 mm offset rear (stock is +64 mm). I am thinking that the +45 mm offsets will move the front wheels out 7 mm and the rears out 19 mm. Will these offsets work without tires rubbing. I also plan to lower the car by about 0.75" all around.
With stock wheel size and using the same rubbers, I used 35 up front and 45 in the rear and it does not rub to my knowledge and looks good. I also dropped 0.75 inches with Paragon kit.
