How Much Noise Does Front Lift Make
![](/forums/images/ranks/3k-4k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
It seems like the front lift on my C8 Coupe is making more noise than I remember from a few weeks ago. Anyone have issues?
![](https://www.corvetteforum.com/forums/images/buttons/collapse_tcat.gif)
Popular Reply
10-10-2021, 05:04 PM
Mine almost sounds like a Coffee BURR GRINDER. . It's loud.
Enjoy while you can.
Received 2,723 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/StJude10.jpg)
no, knock on wood.
E-Ray, 3LZ, ZER, LIFT
Received 9,858 Likes
However, where I used the free XM for a year that started instantly, in the last month have been using the same Thumb drive with ~1000 songs I used in my 2 C7s. However NAV and the USB Thumb drive are both being loaded at the start and I get a "No Device Connected" for sound for a minute or two! It finally recognizes the Thumb Drive! But because I have my driveway memorized to lift, when I start the Lift starts. I do hear it but not very loud over the engine start noise.
As I said, in all other situations my sound system is playing so never hear the lift hydraulic pump motor.
The following 6 users liked this post by Zormecteon:
BlaznZ06 (10-29-2023),
C-ATE (12-18-2021),
dohabandit (11-14-2021),
Klakeman (10-10-2021),
PaulCPO (10-29-2023),
and 1 others liked this post.
The only time I hear anything from the lift is when I am in my garage (it is set to lift in my driveway) when I shut the engine off. As it lowers, I can hear a very, very slight noise or hum.
Sometimes I wonder if the lift can react fast enough though. There is a restaurant I go to frequently that is right off of a well traveled highway with a 55 mph limit, and everyone wants to even faster. So, I don't slow down until I am close to the turn (I do signal and slow properly so the drivers behind can safely slow down). But there is a cutoff speed above which the lift will not activate, so I dont know if there is enough time below that speed before the turn into the small dip for the car to be fully lifted. Cant say I have ever scraped though.
The following 3 users liked this post by 16falcon:
Amazingly minimal.
The following 2 users liked this post by ericok:
Zormecteon (10-11-2021)
The following 2 users liked this post by Bburr:
PColasanto (12-17-2021),
phalse (10-29-2023)
Update - I reported earlier no noise or nearly no noise. Now, at 1600 miles or so, it makes a noise. I would describe it as the typical sound that a noisy electrical hydraulic pump makes. It would not concern me if it always made that noise, but since it was quiet and now is not, I believe it may be a defect. Has anyone with this noise taken it to a dealer for evaluation? If so, what was the result?
![](/forums/images/ranks/100-500.gif)
RWFERRANTE (12-16-2021)
Front Lift completes in 2.8 seconds raising the front 1.5 inches and operates when vehicle is under 24 mph. At 20 mph the front is completely raised in about 5 car lengths.
kitesurfer (12-18-2021)
I had a 2021 coupe that I traded for a 2022 HTC, I only have about 200 miles on the 2022, but I am sure that the front lift is significantly louder than the one on my 2021.
I've had farts that were louder than my front end lift. I hear it, but so what?
![](/forums/images/ranks/4k-5k.gif)
It’s a fairly loud sounds a bit like a small 12V tire air compressor.
The following 3 users liked this post by gdb069:
It's probably the tires
My lift got louder in time. I found the lift reservoir cap seal was out of place and seal was leaking. I corrected the seal and added a little fluid which corrected the problem. Check your fill level.
