Jack Stand Locations?
V Vette (03-17-2024)
So while at Spring Mountain. During the owners school. They had a slide where they discussed lifting the car. They said to locate the floor jack at the tie down locations to lift the car. And then place the jack stands at the lift points.
I thought this was pretty interesting and I wish I could provide the power point slide. So I am going off of memory. Perhaps, I misunderstood what they were saying. But it was something that stuck out and caught my attention. Especially considering the considerable amount of discussions on the forums.
Also, if you watch the Savagegeese Corvette video. The one where they have the Chevrolet engineers working on the the car in the garage. If you notice, they use four regular jack stands and a floor jack to completely lift the car. I reviewed this video but it is too edited and they don't show where they are placing the floor jack. But it shows that they are accomplishing it without any special jack stands or lift.
I was trying to understand this procedure as well and I haven't found an answer here nor have I seen a YouTube video showing as such.
Can anybody confirm? The PPT slide would be awesome.
Received 1,205 Likes
same problem. I read more “don’t lift anywhere except on the oblong jackpoints“ then I do saying it's ok to jack somewhere else. And taking off the underclading to find jackstand points around the front and rear axles is too much hassle. So the only thing I’ve come up with is:
-jack on the jackpoint,
-slide $65 Rhino ramps underneath the tires,
-lower down on the ramps,
-then use jackstands on the jackpoint.
before you ask why not drive up on the ramp, I don’t like driving up the ramps and they are in the way of the jackpoints.
A cumbersome workaround, but it works.
Kbmwgt (03-22-2024)
Need to remove plastic covers to use these. I generally put jack stands on the rear cradle where shown in yellow in the middle picture and then use my scissor jack on my 4 post to lift the front by the pucks but have put jack stands under the yellow indicated bars in front with no issues
MEZR (03-21-2024)
My interpretation was all of the locations marked in green or yellow are ok to lift the vehicle by and can support a jack stand. Some are however fairly far inboard so although front/ rear weight distribution is not an issue, you need to be aware of that. I was simply showing all the locations that appear to be ok to support weight of vehicle.
I do it the way Spring Mountain does it. That way the official lifting locations are available for jack stands. The round holes in the frame are the tie down locations.
JimB. (03-22-2024)
If you have seen the chassis cut a way the 2 side rails are capable of being lifted with a floor jack at any point. The pad locations are there to keep the car in balance so it won't fall off the lift if you remove the front wheels. So lifting adjacent to the pad locations and then putting a jack stand at the pad is what is done at spring mt. The only thing to consider is to be careful of the plastic body panels when lifting. I have urethane pads on my floor jack.
The following 3 users liked this post by jagtoes:
That's what I do. The rear round hole is close to the CG and lifts the whole side of the car. Handy if you are working on one side at a time. Make sure to use a lifting puck with a locating feature in the hole. You may have to grind down one side of the T to make it fit in the round hole.
Steve Armstrong (03-22-2024)
Very good question, and has been my question also. RKCRLR has stated that he does it that way and appears to be load bearing in the round holes for lifting purposes. Apparently Spring Mountain does the same, as stated by several posters, and SM has a lot of experience in those matters. So, I'm going with it is a safe, acceptable and load bearing solution to the C8 dilemma of where and how to put the jack stands.
E-Ray, 3LZ, ZER, LIFT
Received 9,841 Likes
For the front for sure this could also work and no need to modify the lift pads top. IT COULD WORK FOR THE REAR IF THE JACK STAND IS PLACED CLOSE TO THE LIFT PAD WHERE JACK IS USED. Just be careful and as I do, use two jacks and keep slight tension on the jack for safety.
I bought a small base Jack Stand ($~10 ) that can work as well. Can also use under the "A" frame ball joint as I show in the 2020 pic with a square green symbol.
