Soler Performance TC installed on my C8Z
After 3 months and 2500 miles of ownership on my '24 Z06, I decided to get a Soler unit. Install was pretty straight forward. You insert it at the gas pedal connection. Snaking the wire and mounting the unit was easy. Once installed I started the car and had a check engine light come on. My OBDII reader showed me two throttle position sensor codes which I deleted. Restarted the car and CEL gone. I set the TC to Sport 5 and right from the start out of my driveway, the response was immediate. Car just wanted to go as I applied throttle input. Much better than stock. This mod does not increase power but simply opens the throttle butterflies quicker via applying more voltage to the throttle bodies. To me it was worth the $207 from Paragon Performance. They had free shipping and no tax. Cheaper than buying from Soler direct.
The following 3 users liked this post by c7gsmike:
Is there a feature where you can set the throttle to basically 0% for anti-theft purposes?
I have one, but set it less aggressive than Sport 5. Very good mod.
yes
[QUOTE=spinkick] I have one in my c7 which I love. I wonder though, does the car tune this mod out over time? [/QUOTE]
No. For example, it's not modifying airflow that might be compensated for in the tune through the LTRIMs.
The following 3 users liked this post by Vic55:
Supporting Vendor
Lock Feature for Soler Performance TC
You can use the code SALE5P if you are interested.
Yes, there is. There is a feature called "Lock" which allows you to turn the car on but does not allow any throttle response. It is controlled only via Bluetooth. And also has a valet mode the higher the setting the less throttle response you get.
The following 2 users liked this post by Corvette4Life_01:
KIKNBAK (06-07-2024),
Mike@SolerEngr (06-03-2024)
Supporting Vendor
Email: tiffany@solerengineering.com
Text/call: (850) 512-9262
It doesn't, although the effect is most people drive a little more aggressively, which in turn causes more fuel usage. They do include an efficiency profile that slows down the throttle response. If someone wanted their car to feel like a Prius, they might be able to squeeze a little better in-town mileage from the car. However, a pitchfork mob might descend upon your home and demand you sell the car if you did this.
How long is the code good for? I need to think about it a little bit.
Also if a dealer does notice this, zero chance of any warranty issues?
Supporting Vendor
This code is good until the end of the month but I can always get you another one.
Completely warranty safe. You can also remove the display, hide the wires, and control it strictly from your phone.
Z0HS1CK (06-03-2024)
Supporting Vendor
Glad to hear you like our TC.
Whenever you are ready to upgrade your throttle bodies feel free to give us a call or email.
Call/text: (850) 512-9262
Discount code good till the end of the month: SALE5P
Oh i'll for sure decide before the end of this month. I'll PM you if i run into any issues using the code for the website.
Thanks again!
Mike@SolerEngr (06-04-2024)
Moderator
Received 3,131 Likes
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'12, '14-'15,'22,'23,'24
I have used Soler TC's several times over the years including installed on my current C8 Z06 and as I said in my initial review (last year) I think this is absolutely the best bang for the buck you can do for the new Z platform.
