Depending on Final Power output, looks like a possible 9 Sec advertised ZR1 1/4 Mile!
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
I ran some simulations based on my guesstimated LT7 900/700 FWHP/FWTQ specs compared to the LT6 advertised 670/460 and GM typically conservative advertised 1/4 mile times of 10.6/131....granted I had to play with Aero/trans slip/traction/tires, etc to get the Z06 numbers dialed in with a conservative/achievable 60' time to match the OEM advertised ET/MPH times but once I had these where I wanted them, I added 125 lbs for TT/Intercooler/Plumbing/Etc to bring the Track weight of the Z06 from 3800 to a portly 3925 for the ZR1 but this didn't stop the beast from FLYING!
Remember, just my guesses, you have yours, I have mine and by the way...I nailed the base & Z06 1/4 mile times before they advertised...didn't expect the aero drag so my MPH was a bit off https://www.corvetteforum.com/forums...post1604229495
The following 2 users liked this post by JMB:
CorvettoBrando (06-06-2024),
ZRacerLE (06-05-2024)
I say it runs 9.8 or so. Not sure on trap speed.
A model s plaid traps 155 so anything close to that is insane.
Dig
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![](/forums/images/ranks/5k-6k.gif)
Track weight of the Z06 is close to 3,700 lbs, not 3,800.
My Turbo S at ~3,600 lbs ran 144+ in the 1/4 mile at 800whp so the ZR1 at around the same whp should be capable of 140+, the biggest factor being weight.
I've seen Plaids trap as high as 151 or so, from what I have seen they typically trap 146-148 at around 1,000whp on average but they are extremely heavy, too.
The numbers in the OP are reasonable at 900fwhp.
I do wonder how GM manages the TC on the ZR1 since the z06 already has minor traction issues with it's lower torque figure.
Brooks from dragtimes had his plaid on the strip and the car does lose power depending on SOC. I think 85% or higher SOC it should trap 152-154.
Car Junkie 24 (06-05-2024)
![](/forums/images/ranks/7k-10k.gif)
I will be shocked if it has close to 900 hp.
Location: North/Central NJ - a.k.a. Gotti in the CFNE section
Received 1,570 Likes
St. Jude Donor '05
If this is the final version of the C8 then it will have probably 900+ and be TT FPC with the erays hybrid assist.
If there is a Zora, the ZR1 will be RWD around 800 or so hp.
I say this because everything has been delayed a year + constraints and SUPER slow production. The Z06 was supposed to be 22, eray 23, ZR1 24, etc.
That's my .02c
That's my .02c
I'm not trying to be a dick but based on ACTUAL weight used in this thread https://www.corvetteforum.com/forums...post1605910200 not some bogus GM advertised dry weight that needs a calculated wet weight and driver value, please tell me how my numbers are off and what numbers should be used? I happen to be 6-3" and weigh 200 lbs so that's exactly what I used! Peace brother...
I agree with you, the ZR1 might see sub 10 second 1/4 mile times in the right hands. I prefer road course, so I would rather see more focus on weight. That would also help a little in a straight line acceleration.
I'm really not trying to be difficult....did you miss the 1st sentence where it clearly states "3600 lbs with 1/3 tank of gas and no driver"? NO ONE I know races their car with a full tank of gas lol! I race with 1/4 to 1/3 tank myself so 3600 +200 = 3800 lbs dead on for a Z06 at the track and my simulation!!!
![](/forums/images/ranks/4k-5k.gif)
Oh yeah.....we care about everything. I believe the car was built to go at 9.90s. 10.00s anything could be disappointing. Nurburgring should be a sub 7 second for sure, if GM ever disclose the results.
JMB (06-05-2024)
d16dcoe45 (06-06-2024),
TRANS DAMM (06-06-2024)
