Question re the tall rear wing/Z07 rear wing.
The Consigliere
Received 5,514 Likes
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
For those that have these, it appears the two stanchions supporting the wing each have two torx headed screws/bolts on the inside of each stanchion.
So. . . . , can this wing be unbolted and taken off and put back on/bolted up readily?
Interested
Yes, easy to take on and off by removing the bolts from each side.
OnPoint (06-22-2024)
Why would you want to take the high wing off for? Are you planning to drive the car around like that? You're going to have 2 stanchions sticking up, or 2 holes in the back and it will look silly
You need the tamper proof Torx Plus aka 5 lobe bit socket set to remove or tighten them up. I bought mine off amazon, as my high wing was a bit loose after I got back home from a road trip a month ago.
You need the IPR-30 bit.
Please tell me your going to buy these.
![](https://cimg3.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/1800x1800/corvette_c8_z06_wing_risers_1_1800x1800_f609efee8291d06fe585d0b4d005f38f10a15da3.jpg)
![](https://cimg5.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/1800x1800/corvette_c8_z06_wing_risers_carbon_fiber_6_1800x1800_5209f1ef178f50ec53800849611400c8e8c589b6.jpg)
The Consigliere
Thank you gents.
That's what I needed to know.
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
