Ethanol free gasoline?
I was at a Shell station (in Ontario) yesterday and saw a notice on the pump stating their Premium gas was ethanol free. Is anyone here aware of any other brands that do not add ethanol to their gas? A marine mechanic advised me to use ethanol free gas in my boat whenever possible, and I believe it may be better for the vette, especialy during storage. Any comments?
There is an issue with ethanol being corrosive when sitting for long periods.
Accelerated Corrosion and Conductivity
Ethanol can accelerate corrosion in steel UST systems by scouring or loosening
deposits on the internal surfaces of tanks and piping. If a corrosion cell exists, the
ethanol can accelerate (scour) the corrosion cell and cause a perforation. As mentioned
above, ethanol is not compatible with soft metals such as zinc, brass, copper, lead, and
aluminum. These metals will degrade or corrode in contact with ethanol and possibly
contaminate a vehicle’s fuel system.
Tank leak detection equipment composed of certain metals (mentioned above),
polymers, and elastomers may not be compatible with ethanol. Because ethanol has a
higher conductivity than gasoline, capacitance probes may not work in ethanol-blend
fuels. Verify the floats used in magnetostrictive probes are alcohol compatible and that
the ATG system is properly calibrated for ethanol.
Since ethanol-blended fuels attract and hold moisture, ethanol content can contribute to causing corrosion of tank material in aluminum fuel tanks. Corrosion material can clog fuel filters and damage injectors, carburetors, and other fuel system components.
Stainless steel and plastic fuel tank materials are not affected by ethanol-blended fuels. However, ethanol-blended fuel can act as a solvent, loosening and washing old deposits or contaminates into the fuel system.
In communist red Canada, our Oligarchs tell us that it is better to consume 11 acres of corn to add 15% ethanol/gasoline to fuel 1 car for 1 year instead of feeding 7 humane beings for 1 year from that 11 acres, and it is necessary to subsidize ethanol production/distribution with borrowed money from the best banking system in the world, and from the new breathing tax for CO2.
Got to love Canada.
All together now:
Oh Canada, Our Home and native land.......
LA La lala.. la la la lala la
Does anyone know the words?
Got to love Canada.
All together now:
Not just Canada,ethanol free fuel at the pump is likely a thing of the past.Even Nascar is giving up its redneck hillbilly ways,going to an E15 blend and get this-fuel injection in 2011!Welcome to the technology of the eighties boys!
Got to love Canada.
All together now:
Got to love Canada.
All together now:
Now, the Petro Canada 94 is the same as the old Sunoco 94......10% ethanol. I have no idea how much ethanol is in their 91........since I only use 94.
Esso may be ethanol free, but I have not used it since they changed their formulation when they changed to low sulphur content. I was getting consistent drivability issues with Esso Extra. The car would stumble badly when first accelerating. Switched to anything elso and that stumble completely disappeared.
Sunoco that was the 1st to use ethanol in all their gasolines before government regs required it.
http://www.sunoco.ca/default.aspx?ID=2379
...We take pride in our responsibility to the environment. All our gasolines are enhanced with ethanol – a clean burning, renewable resource. It's also a gas-line antifreeze in the winter. All Sunoco gasoline is certified with Environment Canada's EcologoM under the Environmental ChoiceM program.
For new vehicles: It keeps them cleaner & a great fuel line anti-freeze.
(But their mileage on the race track has suffered.)
& they make over 600+ hp in their Chevy small block 5.0L V8 race engines.
The new mid-gen Holden Commodores are now "hybrid" vehicles.
They get the green Hybrid badging too.
(Hybrid meaning they are E85 compatible small block 6.0L V8's )
& Brazil is really liking the idea (them using E25 as their fuel)...GM is specially marketing it there to them; as a Chevy Omega , in a V6 version.
So I'm confused now. Sunoco bought Petro Can but disolved all of the Sunoso gas stations and kept the Petro can name? Seems dumb to me.
I'll go by a Petro Can station and check their labeling, I'm still pretty sure that the premium doesn't contain Ethanol.
Good info on the Shell gas. Too bad I don't have any real close to me. Do you notice a difference in fuel mileage?
Maybe Sunoco thinks some people will still buy into the PetroCan being Canadian owned and that buying there is supporting Canada somehow.
Peter
Peter
Disabled by request 10 March 2011
I think that Shell is the only one still selling non-ethenol gas (only in the premium), if you read their pumps the 87 & 89 have the regulated "upto" 5%.
As for Sunoco, PetroCan merged with Suncor buying them out, and you will notice that ALL the Sunoco gas stations are in transition to becoming Petro Canada. They are offering the ULTRA 94 (by old Sunoco) at most of their stations.
The government regulated, many years ago, that ALL gas had to contain "upto" 5% ethenol. I have bought from the old Sunoco & currently from Shell, used them in both my C3 (past car) and my '10 Camaro (present car) and don't really feel any difference, nor increase/decrease in gas mileage.
In my opinion, gas mileage is primarily based on your method of driving, the mods on your car (if any), and the tuning of your vehicle.
JUST USE WHAT BEST WORKS FOR YOU & YOUR VEHICLE AND NOT WHAT PEOPLE SAY!
YOUR VEHICLE WILL DICTATE WHAT IT LIKES!
Not all Petro Canada stations will carry Ultra 94, but the ones that were recently converted from Sunocos will have it.
It's too bad more brands don't offer a choice. If Shell can offer it, why not Esso or Petro Can. I've read that the ethanol blend is fine as long as it's used within 6 weeks, afterwhich it may begin breaking down and separating. Also, the octane level in the remaining fuel may be below what's advertised because the ethanol was used in part to boost the octane rating.
