GM LS ST2126LSR - SHORT TRAVEL AXLE OILING https://www.xplosiveperformance.com/...le-oiling.html
FREE SHIPPING CONTINENTIAL US
These Johnson's lifters are the short travel slow leak down race-style lifters with axle oiling for all LS engines not running DOD/AFM. These do use a tie bar, so you will remove the plastic lifter trays for these lifters.
GM LS Short Travel Axle Oiling - 2005 and up V-8 LS1, LS2, LS3, LS6, LS7, LS9, L92, & LQ9
Hydraulic-Roller
Will Accommodate Higher Open Spring Pressures of 500+ lb.
.058" Total Plunger Travel
.035" Recommended Pre-Load +-.005"
Set of 16 Lifters https://www.xplosiveperformance.com/...le-oiling.html
