Gen VI block & Mark IV head compatibility
![](/forums/images/ranks/3k-4k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Will a new Gen VI 454 block & factory hyd roller cam work with Edelbrock Performer Mark IV style heads and aftermarket roller rockers? If so, what head gaskets to use?
(answering a question from a co-worker)
Thanks in advance.
Thanks in advance.
OK, maybe I should rephrase the question: Will a new style Chevy BB short block work with old style BB heads?
![](/forums/images/ranks/7k-10k.gif)
I'm not a BBC guy, but when the Gen VI stuff came-out, I recall that CHEVY HIGH-PERFORMANCE did several build-ups, using Mark IV heads on Gen VI blocks (I think odd-ball/adaptor-type head gaskets were used?), but I'm going strictly from memory here...
My car is living proof that the Mark VI block can be used with any Mark IV heads. I have 1969 Oval ports sitting atop a 1998 454 block, destroked with a Mark V 366 truck crank to yeild a 427. The water passages and lifter valley castings were modified for the Mark VI block to be compatable with all Big Block heads. The mark V blocks are the special ones. So as long as your block is newer than 98 (I believe that's when Mark VI went into production) your good to go!
![](/forums/images/ranks/100-500.gif)
