For those with modified motors/exhausts, how do you get past a smog check?
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
You can just register at a house in a non smog area of a county. The owner of the house you pick doesn't even have to know because you can have the dmv paperwork/renewal mail sent to a different address. I know a guy that didnt even know who lived where his car was registered. He drove up to North shore Tahoe found a cabin with a attached garage and used it. All his renewals came to his other address and cabin owner never knew his address was being used. Most out of the way cabins up at Tahoe for instance dont have mail delivery so another address is common for all mail.
It isnt a problem with cops if they ask whats up with 2 different addresses as you just tell them the car is garaged up there at your vacation home because your garage is full here in bay area but you bring it down to bay area sometimes so your drivers license can still have other address on it. Your DL address and car registration address do not have to match but DL must be your main residence if they ask.
And if you dont wanna do that you can go to the underground. There is a vast underground of smog techs that will not do a visual, and next year when no more sniffer test on 2000 and newer vehicles it will be even easier to cheat.
![](/forums/images/ranks/2k-3k.gif)
Hell I'm E85 burning clean as hell and no way would it pass the new 2013 check because tune is radically altered for the E85. I could easily change back to stock tune if I ever needed to actually smog my car but it might fail anyway if they pick up tune has been changed back to stock fro ma modded tune.
I talked to a programmer working on the 2013 stuff and he said it will even pick up if fan settings, timing, fuel stoich and such are changed from stock and throw a red flag.
This new program stinks from the get go but some other states already use it to some degree. The part of it is stupid because the tune can be changed for cleaner burning fuel like E85 yet the bozo's for CARB cant see that and have a work around for those people people.
Andy of A&A Corvette is paying the mega bucks now to be approved by CARB and ARB for his aftermarket tunes for his supercharger packages. I'm afraid to say its really going to suck for ANYONE with an aftermarket tune UNLESS the tune is approved by CARB.
![](/forums/images/ranks/4k-5k.gif)
as long as they cant see history we can deal with that, but if they can what are you suppose to do at that point if you have ever had a tune....sell the car? lol
They should just have the Sniffer and nothing else as long as it passes it shouldnt matter
![](/forums/images/ranks/7k-10k.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
Problem with only a sniffer test, when a car is fully warmed up it pollutes much less than when warming up after a cold or semi cold start and this is what needs to be checked and they cant. Sniffer tests really are a lousy way to smog a car. The computer data tells much more by far.
In 2013 they will be checking sums for various data from current vs past information collected either by dealer or smog checks. If the check sums dont fall within a match range then you fail for further checking whats going on. This is where if you have changed you're tune after last smog check or dealer data gathering when warranty work was preformed the checksums will not match and you fail.
In short this is how it works:
At the smog test, they connect to your PCM via the OBD2 port and read these things (using Mode $09):
- CAL ID for each segment,
- CVN for each segment,
- VIN of your vehicle,
they then use the VIN to look up a database containing valid CAL ID and CVN values for your VIN (this is already in place for 2005+ cars);
the CVN's are like checksums; when tuning software writes to the PCM, the tuning software calculates what the CVN should be for each segment and writes it to the PCM; when you turn on the key, the PCM performs the same CVN calculation and expects to arrive at the same values;
if you have significant engine mods, you would have had your PCM tuned, which means the CVN for the engine segment now differs from original...
if you deleted codes, then the engine diagnostic segment CVN differs...
if you had your auto trans tuned, then the trans segment CVN differs...
if you changed your ring/pinion ratio, then your speedo segment CVN differs...
if you changed your fan on/off temperatures, then your system segment CVN differs...
[ if GM reflashed your PCM for some reason or other, CARB will know about it (since the PCM is an emissions device), and the new CAL ID and CVN will end up in the database ]
if your car is a 2005+ they will definitely see the differences in CVN values, and they will fail you;
if your car is 2000-2005 they may still be able to pick up on these differences, even tho they didn't legislate for a database for cars prior to 2005; that doesn't mean they don't have a means of looking up and checking (they have had the ability to store the CAL ID and CVN values from all your previous smog tests, and they have the computing ability to detect differences, they just can't necessarily compare them to the OEM values);
I'm glad I dont have to worry about this bulls***
All this in a state with 11 million Ilegal Aliens, 30 percent of the NATION'S welfare recipients, Prisons and Jails so "full" basically only "violent" offenders are incarcerated for any time. And, broke.
For those with anything other than a stock car it's time to start considering all the loopholes in the system. Registering it in another county. Registering it out of state. Finding shops that will overlook the visual. Etc, etc, etc....
...considering the intent of CARB is no longer about doing the right thing for the environment but about making money
Has anyone actually confirmed they're doing some kind of checksum testing against the calibration tables? Or are we just guessing?
No offense intended to Z06Supercharged, but I don't see this written in the law anywhere.
Corvette Cowboy
My thing is having 2 ECU'S one to run on and one when I go in with the very first time when this starts buy it from dealer and the paper work with a tune on it
hope to hell it works lol
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
That's like failing someone because they put their stock manifolds back on the car.
![Crazy](https://www.corvetteforum.com/forums/images/smilies/crazy.gif)
Ya that's where I'm confused, that'd mean cars literally a couple years old would become junk and not able to be registered which is retarded since most with tunes burn cleaner lol
#33
Location: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
That sucks, Here in Nevada all they do is hook up to the OBDII port, They don't even open the hood.
Mr.Bill
Mr.Bill
#34
#35
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
#36
![](/forums/images/ranks/500-1000.gif)
I did talk to a friend who works at BAR. He said that ARB won't budge on the aftermarket cans, but the vendors are more than welcome to try to have them certified. But that's the Catch 22. Too expensive to do and not enough market in the state, so the vendors pass on it.
#39
![](/forums/images/ranks/3k-4k.gif)
So, if this is the case. You purchase a smog legal supercharger kit and have it installed at a local performance shop or do it yourself. You will then need to go to a smog shop, or go to a referee to qualify the new tune so it can be the new baseline?
DJ
DJ
#40
There are easy loopholes to beat the smog check to even worry about anything they come up with. California is just a joke with how the government just runs all over people there and CARB is at the top of the list
