Higher mileage DCT failures?
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hi Folks
It appears that DCT failures have been a hot topic on these forums. One thing I have noticed that one thing these failures seem to have in common is that most of them seem to happen at relatively low miles. ie less than 10,000 miles.
I would be interested in comments from folks that have DCT issues at higher mileages. I am curious if for the most part if you make it through the 1st few 1,000s of miles then the Termec tend to be reliable ?
The following 2 users liked this post by formulaWA:
Fishfryer527 (06-20-2024),
V Vette (06-20-2024)
![](/forums/images/ranks/5k-6k.gif)
Most of the DCT failures appear to be infant mortality but I've seen a few high mileage failures posted. We'll know better once there are more high mileage C8s out there. Could take a while, this is Corvette owners were talking about.
kromdom (06-23-2024)
IF the theory that manufacturing debris is the root cause is true, then I would expect most failures to happen at relatively low mileage.
But if that really were the cause, you'd think Tremec and GM by now would have figured out how to make sure any debris is cleaned out.
![](https://www.corvetteforum.com/forums/images/ranks/veteran_navy.png)
Received 20,008 Likes
'20-'21-'22-'23-'24
![](https://www.corvetteforum.com/forums/images/ranks/cf20.jpg)
![](https://www.corvetteforum.com/forums/images/ranks/cf-stjude20.jpg)
^ I agree - this has been going on since the 2020 model year - surely they could come up with a cure for the DCT problems by now.
![](/forums/images/ranks/100-500.gif)
It’d bet it’s not a issue of figuring it out, they probably have identified the issue and decided it’s cheaper to replace failed units than to avoid the failures in the first place
The following 5 users liked this post by StfDrmsRMadeOf:
BasicMember (06-20-2024),
Dennis08 (06-21-2024),
meflyfrc (06-25-2024),
Red Mist Rulz (06-20-2024),
undecided1965 (06-21-2024)
MikeinAZ (06-25-2024)
There may be some truth to this. The DCT is very complex and I suspect that there is not a single cause of the problems but rather multiple problems. On its own each individual problem is probably rare enough that it wouldn't require a fix but fixing all the potential problems may be costly.
There doesn't appear to be a common theme, mileage-wise; I've seen just as many posts from 0-1,000 miles as 10,000+ miles.
![](/forums/images/ranks/3k-4k.gif)
Not that I have anything to add .....
23K+ miles on '21. .. at about 21.5K .. Check engine light, lost the even number gears. .(Middle of N Dakota) . Drove to nearest dealer (Bismark-200+ miles). Gears came back before I arrived at dealer. He cleared code. No more problem to get home (1300+ miles)
Went to my servicing dealer . There was a TSB on the code (loss of communication) known before I left on my trip. They did their thing. .. No more since.
The following 3 users liked this post by Zormecteon:
I’m one of the higher mileage guys. Daily my 2021. At 49K I got Rear axle system off message. Car drove fine, but obviously was not getting the ELSD activating properly. Ultimately dealer and GM decided the valve body needed to be replaced. Several more weeks of national back order on the valve body and GM decided to just swap out the whole transmission. In my case, this actually worked quite well. I got the latest version of the DCT redesigns and GM gave me DCT coverage up to 149,000 miles. I’m now at 63,000 miles and haven’t had any issues since the replacement.
My thought on all of this is that the valve body seems to be the culprit more often than not. I have yet to hear of any catastrophic mechanical failures of the DCT itself.
The following 6 users liked this post by neogenesis:
4thC4at60 (06-25-2024),
Cumbers (06-25-2024),
jpmotorsport (06-25-2024),
kromdom (06-23-2024),
langhorne_bill (06-21-2024),
and 1 others liked this post.
I guess I’m hopeful that the valve body can get revised/figured out in the aftermarket eventually because that should be a relatively inexpensive fix down the road as these cars age.
![](/forums/images/ranks/1k-2k.gif)
For gods sake, buy a PDK, reverse engineer it and pay a licensing fee for whatever you need. gm made $10.1Billion last year (income) throw a few million Porsches way and FIX THE TRANSMISSION…
I feel better now…. Nah not really
I have another idea… take five self destructed DCTs and send them to Porsche and ask very nicely (can you fix this so it won’t break?). The German auto industry is known for its metal work. Super strong alloys, and machining to super tight tolerances. My guess it has something to do with either or both of those. The failure of some alloy or parts that need to be to 4 decimal places and they struggle to hold 3…
gm could be using inferior materials and not even know it. Lots of problems with steel and titanium quality in automotive and aviation. Whenever you chase cost too aggressively you have quality lapses.
It just should be resolved by now. Five years is a long time.
rmorin1249 (06-23-2024)
