[Z06] fuel level
fuel level
Just wondering about how much fuel is left when other z owners fill their tank. I replaced my fuel pump and sending unit with racetronix e85 compatible pump ,sending unit and harness. I didnt own the car long enough to measure the old set up before I did the upgrade. When my needle touches the empty mark and I get the warning message It seems there is just shy of 3 gallons left. Usually takes 15.6 or so to fill. Thanks for any input. 2006
I never let my tank go below 1/4 if I can help. Fuel is what cools the fuel pump, so running the tank low causes the pump to overheat and prematurely bun out the fuel pump.
Good advice. Thanks👍
I tried to burn the last bits of the Winter gas out and ran mine down until the second warning "low fuel" triggered on the DIC. I think I put around 16.2 in it after that.
