Full Official Specs for the 2023 C8 Revealed
Chevrolet has released the stats and specifications for the 2023 Corvette Z06, and there's a lot to unpack here for us numbers geeks.
![](https://cimg1.ibsrv.net/cimg/www.corvetteforum.com/75x75_85-1/9/4-sema-2021-holley-chevrolet-c8-645009.jpg)
![](https://cimg1.ibsrv.net/cimg/www.corvetteforum.com/75x75_85-1/985/2023-Chevrolet-Corvette-Z06-004-644985.jpg)
![](https://cimg2.ibsrv.net/cimg/www.corvetteforum.com/75x75_85-1/986/2023-chevrolet-corvette-z06-306-1635192908-644986.jpg)
![](https://cimg3.ibsrv.net/cimg/www.corvetteforum.com/75x75_85-1/987/2023-Chevrolet-Corvette-Z06-005-644987.jpg)
![](https://cimg0.ibsrv.net/cimg/www.corvetteforum.com/75x75_85-1/988/2023-chevrolet-corvette-z06-302-1635192905-644988.jpg)
![](https://cimg1.ibsrv.net/cimg/www.corvetteforum.com/75x75_85-1/989/2023-Chevrolet-Corvette-Z06-019-644989.jpg)
The Power
Let's start with the shining star of this amazing package. The new 5.5-liter flat-plane crank LT6 V8 has a bore of 4.104 inches and a stroke of 3.150 inches. The block is manufactured from A319-T7 sand-cast aluminum and features pressed-in iron cylinder liners and four-bolt main bearing caps with A356 T6 cast aluminum heads. The DOHC 32-valve mill is capable of a massive 670 horsepower at a screaming at 8,400 RPM and a max torque of 460 lb-ft at 6,300 RPM. The Tremec 8-speed dual-clutch transmission is designed with a shorter 5.56:1 final drive for the Z06.
Suspension Setup
The suspension setup at the front and rear is a short/long-arm double wishbone system. There are forged aluminum upper and cast aluminum L-shaped lower control arms and monotube shock absorbers at work. The Magnetic Selective Ride Control 4.0 is an option. And the Z07 performance package gets its own specially tuned version of the Magnetic Ride Control system.
>>Join the conversation about the specs of the C8 Z06 right here in the Corvette Forum!
Brakes
The Z06 comes with Brembo brakes at all four corners. The front wheels are equipped with 6-piston calipers and 14.6-inch rotors. At the rear, there are 4-piston brakes with 15-inch rotors. The Z07 package brings in carbon-ceramic brakes measuring 15.7-inches and 15.5-inches at the front and rear respectively.
Wheel and Tire Options
The first mid-engine Z06 features a staggered wheel setup with the front wheels measuring 20 by 10 inches and the rear wheels 21 by 13. The carbon fiber wheels shown in the image above are available with the Z07 package as well. The standard tires for the Z06 are Michelin Pilot Sport 4S ZPs. Though with the Z07, Michelin Sport Cup 2 R ZP tires are also an option.
Exterior Dimensions
Gaining 3.6 inches of width in comparison to the Stingray, the Z06 models will measure 79.7 inches wide. The track measurements are 66.3 and 66.1 inches for the front and rear respectively. The overall length of the standard Z06 comes in at 184.6 inches, while the carbon fiber ground effects bring the total up to 185.9. The wheelbase is 107.2 inches and the overall height is 48.6 inches. With the Z07 package and lightweight wheels, the car weighs in at 3,434 lbs.
Interior and Cargo
The interior space is not changed from the base trim. Here we get 37.9 inches of headroom, 42.8 inches of legroom, 54.4 inches of shoulder room, and 52 inches of front hip room. The cargo space remains the same as the Stingray as well, with 12.6 cubic inches of capacity.
For help with service of your car, check out the how to section of CorvetteForums.com
